How much freon
Yeah, but too much and it won't cool efficiently and too little may freeze the evaporator. You can look at the high/low pressures. They will be dependant on outside air temp. Your best bet is to take it in and spend ~$100 and have the line evacuated, have a vacuum held on it to check for leaks, then have the freon added back in measure in weight instead of pressures. Much easier that way.
ElGuapo
05-17-2015 07:34 PM
brown154
07-18-2011 10:17 PM
