Here's One For Hummerz
Old Oct 20, 2021 | 01:16 PM
Broken Halo's Avatar
Default Here's One For Hummerz
My '08 Alpha check engine light came on, (first time in the 14 years I've owned it with 55,000 mi.). The (2) codes were P0172 (System Too Rich Bank 1), and P0175 (System Too Rich Bank 2). Seems strange that both banks would throw the same code so I'm thinking a possible fuel issue. I haven't driven it much the last few months so the gas in it is that old. I use nothing but Top Tier Mobil gas. I just added a bottle of Techron Concentrate, filled the tank with fresh gas and cleared the codes with my scanner. Upon restarting the check engine light stayed off (although I haven't driven anywhere yet so it could come back on). Your thoughts? Thanks!
Old Oct 20, 2021 | 01:31 PM
Fill it with fresh Marathon fuel as needed and drive it 500 miles...........report back. That ought to do it.
Old Oct 20, 2021 | 02:19 PM
Old Oct 20, 2021 | 03:39 PM
Cleaned the TB & MAF 20K ago. Shouldn't be due this soon but I guess I could give it a try.
Old Oct 20, 2021 | 04:16 PM
Great place to start. What air filter are you using? Maf cleaning maintenance should be done more frequently with an aftermarket af installed. Can you check fuel trims? If so check fuel trims with maf disconnected. Also make sure to clear codes history.
Here's a recent vid showing maf cause (clean it before replacement):
Old Oct 29, 2021 | 07:37 AM
Update: I cleared the codes and they have not returned....haven't done anything else but add some Techron Concentrate and new gas. I don't think THAT was the solution, as I haven't put that many miles on it since the codes first popped. Must have just been a glitch.
Old Nov 2, 2021 | 03:47 PM
Halo, mine did it once. Exact same codes.
Cleaned the MAF, Tbody and made sure no air leaks from the air box to the TB. The small breather hose for the intake had a small hairline crack. Swapped it out and...
Never came back again
Old Nov 2, 2021 | 04:35 PM
Thanks Taint, if it comes back I'll do a hose check but at this point I think it was just a hiccup.
Old Nov 2, 2021 | 07:14 PM
Hiccup? I would've pop top a can of CRC Mass Air Flow Cleaner was the first item on the market specifically designed to clean the mass air flow (MAF) sensor in your car, which can increase horsepower, enhance fuel efficiency, and improve engine performance.
Old Nov 3, 2021 | 07:08 AM
Thanks Hummerz, but you're preaching to the choir. Re-read my post #4. Since the problem has obviously resolved itself I still believe in the old "If It Ain't Broke, Don't Fix It"
