Help! P0622 - Generator F-Terminal Circuit error code
Old Aug 23, 2019 | 01:01 PM
CarlosC's Avatar
Default Help! P0622 - Generator F-Terminal Circuit error code
So soon after I got an error code for the oxygen sensor, which I replaced and is now fine, I got a P0622 Generator F-Terminal Circuit error. This results in the battery light going on about 30-45 seconds after the vehicle is turned on and it stays there until its turned off. I have since replaced the battery (Bosch Premium) and the alternator (OE GM/AC Delco) but the battery light and error code still come up (even after clearing the code). The truck otherwise starts and drives perfectly fine, but the battery light going on is annoying. I had two different shops check both the battery and the alternator to make there were no issues, and in both cases, they checked out perfectly fine. Could it be some sensor or fuse? Not sure what to check next...
Old Aug 23, 2019 | 01:11 PM
Replace the battery terminals and check ALL your ground wires.
Old Aug 23, 2019 | 01:14 PM
https://www.troublecodes.net/pcodes/p0622/ read it it is very informative and explains the reasons that trigger the code. it can be as simple as bad battery connectors or as bad as a bad PCM
BrokenAxle
17
Jan 5, 2017 06:01 PM
09 Black H2
Feb 4, 2015 08:41 PM
Happy Hummer
Mar 17, 2013 12:47 PM
Champ53
Jul 19, 2011 02:26 PM
NoDakH3
Mar 18, 2009 06:50 PM
