HELP!! Front Driveshaft/Differential mounts/bushing problem
Old Aug 21, 2017 | 04:30 PM
  #31
Kamikazi's Avatar
Doc and Tainter.... One last update and I'll drop this. Promise!
Just got off the phone with Bruce at Suspension Restoration in Modesto. He has sold off his business and partially retired but kept the Hummer parts. They do not show up on suspension.com and they have no idea of how he was handling these so if anyone else is in need give him a call directly!
(209) 578-5101
(800) 291-5340 ORDERS ONLY
(209) 578-0562 (FAX)
Suspension Restoration Parts Co.
319-C Motor City Ct.
Modesto, California 95356 USA"
Old Jul 30, 2019 | 12:05 PM
  #32
Ron Henderson's Avatar
Default Cheap Easy fix for this problem.
Originally Posted by Whitey602
This has been very helpful guys..My mechanic just told me that I am missing the front diff bushing on my '07 H3 I too felt the shock of the estimate to replace the crossmember 425$..I read here about the bushings from suspension.com called and spoke to Bruce and you are right he is a good guy. He let me know that the bushings will require some modifications to fit and I see below will need a lock washer with the nut. I was hoping someone could give me step by step how to mod the bushing and any other parts/tools needed for the job. My mechanic is willing to install just the bushings if they fit but, cant do the mods himself..coporate type place..
I spent hrs trying to find a simple solution as I had made my 1st replacement bushing and it only lasted a year then after beating my head on a tire I found the best possible solution yet .and almost all parts stores have acess to this .it is a Moog part # K6572 and will only cost you approx. $12 now that saves plenty for fuel to go try it out after you fix it !
Marco93l
May 24, 2016 10:24 AM
surfnaked
May 1, 2013 07:16 PM
204H3T
Mar 17, 2013 02:48 PM
thefloridajohnsons
Feb 24, 2013 05:43 PM
roastbeef
Nov 14, 2009 10:58 PM
