Help with Emissions Readings
Old Sep 21, 2021 | 10:09 PM
KU1525's Avatar
Default Help with Emissions Readings
Hoping to get some insight on some emission readings and graphs on my 2008 5 Cyl (111,000 miles). These readings came from a Veepak OBDCheck BLE bluetooth scanner paired with the Car Scanner iPhone app. No codes other than P0300 and no noticeable performance drops. Some background: replaced OEM exhaust manifold/catalytic converter with Walker manifold, replaced upstream and downstream O2 sensors with brand new OEM sensors, and replaced ECT sensor on June 8. Not really related but I've had P0300 code for years now, with a frequent rough start unless I press the gas and hold the RPMs around 2,000-3,000 for a few seconds (
). Can't be positive, but I think I have soft valve seats on one or more cylinders. Also, main catalytic converter has been burned for years and I have not replaced that one yet.
But for the actual emission tests, you can see below that I have "not passed" listed for Evap system, secondary air system and O2 sensor heater. I can't tell through the app what specifically might be the issue. Again, no codes thrown ever for any of these systems before. I've been doing some research to try and learn more about the Evap system and common failures but haven't seen anything definitive.
Emissions Tests
Here are a few other graphs that might help shed some light on anything specific I should look into (images captured at idle after driving in town for 30 minutes:
Evap Pressure/Evap Purge combined
O2S1 volt/trim on left and O2S2 volt/trim on right
As you can see, I'm not getting any readings for the bank 2 trim and I don't know what that means. Any help or direction I should focus would be appreciated.
Old Sep 22, 2021 | 08:50 AM
I5s only have one bank.
You may have a defective O2 sensor if it is not heating properly.
Old Sep 22, 2021 | 05:47 PM
Old Sep 22, 2021 | 10:16 PM
KU1525's Avatar
Always wondered about SeaFoam. Have you run some through on yours @hummerz ? I put two bottles of Techron in not that long ago but didn't really notice any difference. Actually thought my rough startup issues got slightly worse and became more frequent after switching to Top Tier gas (Phillips 66) only and the Techron.
Old Sep 23, 2021 | 08:21 AM
Every year! When I bought mine it had a p0300, induction cleaning took care of it. Code never returned over 9yrs later.
Nick Zubick
Oct 3, 2018 07:51 AM
jman1335
Sep 16, 2017 01:49 PM
gasguzzler4mpgonthetow
Aug 1, 2014 07:12 PM
H3 Alpha Dog
Jun 2, 2014 02:59 PM
FLH2
Mar 28, 2008 08:16 PM
