Having a huge power loss issue
Old Jan 31, 2017 | 04:18 PM
  #21
groomsxxx's Avatar
$1470 for reman trans with all upgrades.3 year, unlimited mile warranty and $600 install.
Old Feb 2, 2017 | 08:58 PM
  #22
groomsxxx's Avatar
Cooling Pans : GM 700R4, 4L60 & 4L60E Transmission Cooling Pan
Any comments on this trans oil pan? I think its pretty cool.
Old Feb 3, 2017 | 09:46 AM
  #23
It will NOT fit. The H3/H3T have one only Trans Pan design to clear the front drive shaft, and a special filter inside the pan for use with that pan only.
Old Feb 3, 2017 | 11:13 AM
  #24
You beat me to it Doc...
Old Feb 3, 2017 | 03:40 PM
  #25
groomsxxx's Avatar
thanks . I had thought so . Appreciate the confirmation.
Old Feb 10, 2017 | 07:03 PM
  #26
groomsxxx's Avatar
got the hummer back. yay for that!
Old Oct 24, 2021 | 02:34 PM
  #27
SDEJESUS121's Avatar
2007 hummer h3x with about 53000 miles
I know I should go to a shop, but I am trying to see if anyone here might have a better idea of what is going on. I had been getting the catalyst system efficiency below threshold code. Ignored it for a little bit..Got some random misfire code, then a month ago as I was driving home on the interstate, I lost power and I drove to the side of the road. Cut it off and couldnt get it to really go over 35 mph. Basically was going 35mph at 5 rpm. for about 7 miles to be able to make it home.
I bought a magnaflow exhaust manifold, walker secondary cat pipe, 2 new o2 sensors, properly gapped the NGK Iridium IX Spark Plugs and also installed brand new coil packs as well. Just got it all installed and went for a test drive.. as soon as I got down the road and got closer to 35/40 mph it started to lose its power again and just rev.(it wouldnt go any faster and was just revving)
Does anyone here have any ideas on what this issue could be? Any help is def appreciated.
change the MAP sensor and spark plugs and ignition core it will go away I had the same issue
Old Oct 24, 2021 | 02:45 PM
  #28
Default H3 traction control
MAP sensor regulates fuel 65 dollars ac Delco also sparks and ignition cole and it will all go away
Old Oct 25, 2021 | 01:31 PM
  #29
Great reply to a FOUR YEAR OLD THREAD where the problem was a cooked TRANSMISSION and nothing to do with your comment. Please stick to current threads and AVOID digging up OLD AS DIRT dinosaurs. READ: Old Threads/'Necro-Bumping'
Marcieannt
Dec 4, 2015 07:19 PM
brunoso
Jul 18, 2013 08:53 AM
Cashville
Jun 22, 2012 07:16 AM
dwaxman1
Jun 11, 2008 01:48 AM
