H3 turned over by itself
Old Jul 19, 2021 | 10:26 PM
Hoff's Avatar
Default H3 turned over by itself
Just got back from flat towing the 3 from Wyoming, do it often but when I got home in CA, unhooked put key in ignition, turned to first position and it turned over twice in a row by itself with no start. Turned back took key out, tried again and would only turn over and got code P0171. Took MAF out, cleaned and it started. Parked in garage for 2 days then backed out to wash, sat for 3 hours outside, went to pull it in garage and did same thing but no code or CEL. Waited about 30 min and stared no problem. What gives? Battery is probably 4 years old, have the stinger connectors and has 59K miles.
Old Jul 20, 2021 | 08:11 AM
May be a passlock issue, but the first thing to do is clean the contacts for the ignition switch before replacing anything. There are a couple fairly recent threads on this.
Here is one... Pass lock security system
Old Jul 20, 2021 | 09:47 AM
Hoff's Avatar
Thank you Doc
Old Jul 20, 2021 | 11:14 AM
Forgot to ask, does it have an aftermarket remote start?
Old Jul 20, 2021 | 11:30 AM
Hoff's Avatar
No sir, all stock but Airdoc 😉 and AFE dry filter.
dbphotos
Aug 25, 2025 01:09 PM
Alex DjFlaco
Sep 20, 2020 10:30 PM
maddness038
Jul 28, 2011 10:14 PM
6spd04cobra
Jul 3, 2010 07:58 AM
taz7593
Nov 18, 2008 02:01 PM
