H3 running rough
Old Sep 5, 2023 | 11:33 AM
Kevin Lindsay's Avatar
Default H3 running rough
2007 h3 will not run after 5 minutes. it is idling rough. I have changed the values cover and Gasket, all new high end plugs, new ignition coils and fuel injectors. all new sensors, oil and filter, oil pressure sensor, rebuild transmission, cleaned the cat converter, fresh gas. the only thing that is left in the computer ( I cleaned the connection also.
HELP PLEASE
Old Sep 6, 2023 | 12:17 PM
MOVED. Look before posting. The Hummer Forums Help & Suggestion Center is NOT for vehicle questions, but instead for questions on hoe to use Forum features, like posting pics....
Anyways, now that we have your H3 question in the H3 Section, you should get some answers. Don't know what "high end plugs" are, but if they are not direct OEM ACDelco replacements, they won't last long.
Scan and post any codes, stop throwing parts at a problem you do not understand.
Read this thread and let us know here if you have done items 1 through 7 (4&5 are replacement of plugs with inspection). Acts like it wants to stall/rough idle -No CEL -What To Do:
honda400ex2003
Aug 26, 2012 09:46 PM
drtom
Jan 17, 2011 09:23 PM
summit
Oct 10, 2010 06:46 AM
HummerGuy
16
Sep 6, 2006 11:29 AM
