H3 not cranking
Old Aug 4, 2024 | 03:51 AM
Salbar's Avatar
Default H3 not cranking
Hello guys,
​​​​​​My H3 stopped cranking suddenly when I was trying to solve rough idle problem, turning off on low rpms while reverse parking or on a slope on Drive... In brief after trying to clean battery plugs, car stopped cranking, small rare pulses happened while trying, I tested the map and no signal was coming out from the pcm to start the run relay, park/neutral switch is ok. Still see the "power reduced" on dash, please advice wether it is a failed PCM or else, advanced thanks
Sal
Old Aug 4, 2024 | 03:53 AM
Salbar's Avatar
Originally Posted by Salbar
Hello guys,
Sal
Sorry I forgot to mention the model: 2006, vortec 3500 motor 5cyl
Old Aug 4, 2024 | 03:57 AM
wpage's Avatar
Recheck your terminal connections to battery. If you haven't already consider replacing the OEM battery connectors which are somewhat un reliable.
Old Aug 5, 2024 | 08:56 AM
Replace the crappy azzed OEM Battery Terminal Connectors with a quality aftermarket set like Stingers or your favorite brand. The fist Mod to do to every H3/H3T.
Old Aug 9, 2024 | 10:00 AM
Any update? Have you replaced the OEM Battery Terminal Connectors?
bureau13
Mar 19, 2020 10:26 AM
Zeppelin
Sep 29, 2018 09:47 AM
jens
Jan 27, 2015 02:53 PM
civicrsa
Oct 16, 2014 04:50 PM
Mr_Sandman
Sep 29, 2013 10:36 PM
