H3 Maintenance with 57K
Old Feb 18, 2025 | 04:29 PM
Henrykjr's Avatar
Default H3 Maintenance with 57K
Hey folks just found a 1 owner 2006 H3 with 57K on the clock. Since the vehicle has be in service now for 18 years should I go ahead and do the 150K service on it. I am most concerned with the auto transmission since some towing has been done on the vehicle.
Thoughts?
HK
Old Feb 18, 2025 | 07:24 PM
Old Feb 19, 2025 | 09:01 AM
If you do not know exactly when the fluids were last changed, just like any other used vehicle purchase, change them all. For the H3, motor oil, Trans and filter, front and rear diffs, and the T Case making sure to follow the service bulletin for 06 and very early 07s to add an additional 250ML of fluid in the speed sensor hole after you fill it to the fill hole to get to the proper level for those early T Cases. Take a look at your manual for fluid types and viscosities.
I would also drain the coolant by removing the lower radiator hose and let it go into a bucket and refill with DexColl 50/50.
Welcome and congrats on your find.
Old Feb 19, 2025 | 12:36 PM
I agree with DOC on this. EVERY FLUID and filter needs to be drained and filled. Don't forget to at least test the brake fluid too!
That way you know it has been done and you can start on your own service intervals.
Old Feb 20, 2025 | 03:49 AM
Happy Hummer's Avatar
Fluids have gotten very spendy. Might I recommend to check fluids such as front, rear pumpkins. Trans, transfer. Do change oil. Do check brake and steering.
Wow 57k
Old Mar 8, 2025 | 04:46 PM
wpage's Avatar
Like others...
oil and filter change
air filter
Trans flush and filter
front and rear differentials
You will have covered the bases.
Old Mar 9, 2025 | 12:05 PM
ski.dive's Avatar
You said---'1 owner' 2006 H3 with 57K on the clock
Just ask the owner, when the last time the Hummer was serviced.
Old Mar 9, 2025 | 03:19 PM
Sherry's Avatar
Default 2008 Hummer H3 BCM Antenna
Thoughts?
HK
That sounds like my truck except I still have it but having problems with the TPRM and Key Fobs
jshelk
New Member Area
Jan 11, 2019 07:52 AM
veleno45
Feb 10, 2012 07:01 AM
Cory1745
Aug 9, 2011 12:04 PM
Roelofse
Jul 5, 2011 05:26 PM
BHUM3
Feb 7, 2011 11:06 AM
