H3 Doesn't Start Occasionally
Old Aug 13, 2023 | 03:00 PM
H3NeedHelp's Avatar
Default H3 Doesn't Start Occasionally
Hello I've had my 2007 H3 Sport Utility for a couple of months now. It drove great at the beginning at about 2 months in started to have an issue with it not turning on. I check the fuel rail and didn't have pressure even when priming the pump so I switch the fuel pump. It ran for 3 days then started getting the issue again. I honestly don't think the fuel pump was the issue but figured it would hurt. If I spray starter fluid it would run for a little then stop. After quite some time of it not starting I would ho back to the H3 and it would start. Not sure what it could be, the check engine light is not on when the H3 does start. Any ideas?
Old Aug 13, 2023 | 03:05 PM
Old Aug 13, 2023 | 04:23 PM
H3NeedHelp's Avatar
Do you mind elaborating? I saw a couple stuff online just not sure how to address it. Some places mentions GM anti theft and maybe switching the Ignition Switch is enough. Please let me know.
Old Aug 13, 2023 | 05:14 PM
No need to replace the ignition switch! Open a can>>>> CRC QD Electronic Cleaner!
Clean connector & switch contacts, DONE!:
Old Aug 13, 2023 | 09:51 PM
Happy Hummer's Avatar
Just literally went through this. Did a thread, post about this...I wanted to share this information so as to make it easier for future individuals looking to fix the AntiTheft (PassLock) error.
The module as a whole is:
D1403G (15795322) AntiTheft Ignition housing w/ module. (Available)
The little black plastic PassLock unit screwed to end:
01A1N216
)PA66-GF33(
855610-1302
26124826Currently not available!
Old Aug 20, 2023 | 03:41 PM
H3NeedHelp's Avatar
An update, I've cleaned the contacts and it continued to run for about 3 days. I changed the back part to the ignition switch, did the 3 cycles of 10 minutes to reprogram, and ir has not started. I've jumped back and forward between the old and new back part of the ignition switch and running out of ideas. The passlock symbol appears and doesn't let me start. When I turn the ignition to the on position but not crank it and the passlock light is not on it still doesn't start. If I put some starter fluid it will start for a little then turn off. Any ideas?
Old Aug 20, 2023 | 04:30 PM
CLARIFY your post & STOP using "starter fluid"!
Old Aug 20, 2023 | 04:41 PM
H3NeedHelp's Avatar
I did what Hummerz and Happy Hummer suggested but have not been able to start it again.
Old Aug 20, 2023 | 05:06 PM
Swap relay #66 with #72 & recheck.
Old Aug 20, 2023 | 06:47 PM
H3NeedHelp's Avatar
I just swapped them and still didn't start. I did notice one was 0329 and the other 0330. I swapped it with another 0329 relay and didn't start either.
