H3 differential servo motor.
Old May 13, 2021 | 10:42 AM
OhioH31987's Avatar
Default H3 4WD servo motor
Hi,
I’m new to the forum and hope this is where to ask questions. I have a ‘07 H3 with 89K miles and it won’t engage the 4WD differential and I think the servo motor is bad.
Where is it located and is it difficult to replace. I don’t have the money for the GM dealer to repair. Any suggestions.
Old May 13, 2021 | 10:46 AM
OhioH31987's Avatar
Default H3 differential servo motor.
I have a ‘07H3 with 89K miles and the 4WD differential will not cycle and I think the servo motor is not working.
Where is it located and how difficult is it to replace?
Old May 13, 2021 | 11:21 AM
Check inside the glovebox?
Old May 13, 2021 | 12:09 PM
what you ask for should be on the transfer case not on the differentials. some have removed them and cleaned then re-greased it and put it back. sometimes it just need to be replaced. not too hard to access looks a bit like a wiper motor stuck to the side of the transfer case.
Old May 13, 2021 | 01:37 PM
I MOVED and merged your duplicate question from the New Member section to this one. Works like this. ALL H3 questions go in the H3 Section, ask it once and wait for replies.
What you are looking for is the 4WD Transfer Case Actuator and like bronxteck said it is mounted to the Transfer Case, looks like this (#12 in diagram). Check the wiring to it and clean both sided of the connector with CRC Electronic Cleaner before you replace what ain't broke.
Old May 13, 2021 | 01:39 PM
It would also be helpful if you describe what it does when attempting to change the T Case from Hi to Hi Lock or Lo Lock, when it stopped working/if it ever did, and which Model H3 you have.
I am also going to ask.... have you read the owners manual on how the T Case buttons work?
Old May 13, 2021 | 08:33 PM
Old May 14, 2021 | 03:41 PM
OhioH31987's Avatar
Default H3 servo
Thanks for your help I really appreciate the time and effort. Not much support available these days since GM left all of us hanging when they pulled the Hummer line!!!
In my opinion one of the all time great 4WD....I’m an old timer from the the Dodge Power Wagon days and the International and can’t forget the old CJ 5 Jeep’s.....
thanks again.
Phil Polaski
Cincinnati, OH
altopolski
Aug 10, 2014 01:04 PM
Amhoff
Apr 10, 2013 06:53 AM
08grayH3
Jun 11, 2012 07:58 PM
