H3 Battery Cable Harness
Old Nov 12, 2021 | 06:12 PM
KaiThor54's Avatar
Default H3 Battery Cable Harness
My 2007 H3 Engine light and Battery(voltage) light are illuminated. My mechanic tells me its a bad amp probe per the battery cable.
Its been diagnosed as the entire Cable Assembly needing replacement.
Has anyone installed this “at home”? Im having trouble locating instructions. The part alone, (the assembly) costs close to 200$.
Old Nov 12, 2021 | 06:59 PM
Most likely a short, post the codes.
Old Nov 12, 2021 | 08:22 PM
KaiThor54's Avatar
Default Battery cable Harness
I will pull codes again when I pick it up on Monday. I had the H3 in shop for full front differential replacement/cv axles(not cheap)
*Regarding the battery cable harness, this was the initial Diag.(Below)
Before the repair, every panel cluster warning light was on. After the repair of the electrical issues within the motor and replacement of the differential/cv axles, now only the check engine and battery light indicators remain.
DIAGNOSTICS, FOUND THE ENGINE WIRING HARNESS, MULTIPLE WIRES IN LOOM TO BE BURNED UP, NOT MAKING CONNECTION AND NEEDING TO BE RE-WIRED, SOLDERED, PROTECTED AND REINSTALLED, FOUND ABS SPEEDS SENSOR WIRING TO BE CUT/CHAFFED, REPAIR WIRING WITH SOLDER, AND PROTECTED REPAIR, TESTED SYSTEM, SYSTEM OPERATES AS DESIGNED.
chazyrae94
Apr 22, 2020 10:42 AM
jrock1956
Dec 7, 2017 07:24 PM
Happy Hummer
Mar 17, 2013 12:47 PM
lucky19942001
Oct 20, 2010 03:46 PM
sterlingmarlin30
Oct 18, 2009 07:06 PM
