H3 amp installation help please!!!
Ok, so I am installing an amplifier and sub in my h3 without monsoon and have everything hooked up and ready to go except for the remote wire for the amp. I have looked at all the wire diagram threads and it tells me nothing. The radio doesn't have an amp turn on wire like the monsoon does so I am at a loss on which wire or "color" to splice into to get my amp to turn on. 08 h3
Thanks so much if anyone can help
You could use a Bussmann fuse tap which is usually less than $10 at autostores but I'm not sure if it will fit into the H3 fuse box. You'll just have to use a multimeter or test light to see what turns off with key.
I'm not sure if this will help you out:
If it has monsoon
Battery ORANGE (+) RADIO HARNESS Accessory
Ground BLACK/WHITE (-) RADIO HARNESS
Amp Turn On PINK (+) RADIO HARNESS
LF Speaker (+) TAN
LF Speaker (-) DARK GREEN
RF Speaker (+) LIGHT GREEN
RF Speaker (-) ORANGE/BLACK
LR Speaker (+) BROWN
LR Speaker (-) DARK GREEN/WHITE
RR Speaker (+) DARK BLUE
RR Speaker (-) BLACK
Amp Location LOCATED BEHIND THE TRIM IN THE LEFT SIDE OF CARGO AREA NEXT TO SUBWOOFER.
Steering Cntrls OPTIONAL
Speed Cntrl YES
Radio Security YES
If it has standard audio
LF Speaker (+) TAN
LF Speaker (-) GRAY
RF Speaker (-) DARK GREEN
LR Speaker (-) YELLOW
RR Speaker (-) LIGHT BLUE
Speed Cntrl YES
Radio Security YES
If it has monsoon
LF Speaker (+) TAN
Speed Cntrl YES
Radio Security YES
LF Speaker (+) TAN
LF Speaker (-) GRAY
Speed Cntrl YES
Radio Security YES
Can't find it
If it has monsoon
LF Speaker (+) TAN
Speed Cntrl YES
Radio Security YES
LF Speaker (+) TAN
LF Speaker (-) GRAY
Speed Cntrl YES
Radio Security YES
If it has monsoon
LF Speaker (+) TAN
Speed Cntrl YES
Radio Security YES
LF Speaker (+) TAN
LF Speaker (-) GRAY
Speed Cntrl YES
Radio Security YES
Take a look at this thread regarding necro-bumps. https://www.hummerforums.com/forum/n...bumping-23220/
You could have just asked the question, no need to tie it to an old irrelevant thread.
A stock base stereo has its amplifier in the head unit.
grey714
12-03-2010 09:24 AM
