H3 amp installation help please!!!
Ok, so I am installing an amplifier and sub in my h3 without monsoon and have everything hooked up and ready to go except for the remote wire for the amp. I have looked at all the wire diagram threads and it tells me nothing. The radio doesn't have an amp turn on wire like the monsoon does so I am at a loss on which wire or "color" to splice into to get my amp to turn on. 08 h3
Thanks so much if anyone can help |
OFTEN THE power lead to the radio is red
the power is turned off when u turn key off and open door u could use the red lead to turn amp on it will always be on with the key but who cares the radio is always on anyway |
You could use a Bussmann fuse tap which is usually less than $10 at autostores but I'm not sure if it will fit into the H3 fuse box. You'll just have to use a multimeter or test light to see what turns off with key.
I'm not sure if this will help you out: If it has monsoon Battery ORANGE (+) RADIO HARNESS Accessory Ground BLACK/WHITE (-) RADIO HARNESS Amp Turn On PINK (+) RADIO HARNESS LF Speaker (+) TAN LF Speaker (-) DARK GREEN RF Speaker (+) LIGHT GREEN RF Speaker (-) ORANGE/BLACK LR Speaker (+) BROWN LR Speaker (-) DARK GREEN/WHITE RR Speaker (+) DARK BLUE RR Speaker (-) BLACK Amp Location LOCATED BEHIND THE TRIM IN THE LEFT SIDE OF CARGO AREA NEXT TO SUBWOOFER. Steering Cntrls OPTIONAL Speed Cntrl YES Radio Security YES If it has standard audio Battery ORANGE (+) RADIO HARNESS Accessory Ground BLACK/WHITE (-) RADIO HARNESS LF Speaker (+) TAN LF Speaker (-) GRAY RF Speaker (+) LIGHT GREEN RF Speaker (-) DARK GREEN LR Speaker (+) BROWN LR Speaker (-) YELLOW RR Speaker (+) DARK BLUE RR Speaker (-) LIGHT BLUE Steering Cntrls OPTIONAL Speed Cntrl YES Radio Security YES |
Can't find it
Originally Posted by airborne227
(Post 240854)
Originally Posted by felipepr1
(Post 352776)
I went to a place because the radio is kicking in and out and they told me was the radio amplifier. My H3 don't have the subwoofer and the dealer say my truck don't show to have it. Can you advise if the H3 base has it or not, and where is located?
Take a look at this thread regarding necro-bumps. https://www.hummerforums.com/forum/n...bumping-23220/ You could have just asked the question, no need to tie it to an old irrelevant thread. A stock base stereo has its amplifier in the head unit. |
