H3 Alpha with P0422 and stab sys traction failed
Old Oct 4, 2019 | 02:03 PM
daniel5455's Avatar
Default H3 Alpha with P0442 and stab sys traction failed
My 2008 H3 Alpha with 98K miles has the check engine light and when i checked the code all i see is P0442 Evaporative Emission System Leak Detected (small leak) Also every once in a while i will see SYS STAB TRACTION FAILED. Truck runs fine. Any advice on how i can try to find the leak without a smoke machine? I was reading that it may be the cannister valve behind the front Tire but i dont want to replace it if its not the issue. Also what is the most common reason for the SYS STAB TRACTION FAILED error?
thanks in advance
Last edited by daniel5455; Oct 4, 2019 at 03:35 PM. Reason: Wrong Code in the Title
Old Oct 4, 2019 | 02:22 PM
OBD II Fault Code
  • OBD II P0422
Fault Code Definition
Code P0422 indicates that the Bank 1 Main Catalytic Converter's emissions efficiency has fallen below the minimum allowable limit. This threshold is tracked by a Catalyst Monitoring Oxygen Sensor located on or near the outlet of the Catalytic Converter.
P0422 Symptoms
  • Check Engine Light will illuminate
  • In many cases, no abnormal symptoms may be noticed
Common Problems That Trigger the P0422 Code
  • Defective Catalytic Converter
  • Engine misfires have damaged the Catalytic Converter
  • Internal engine damage resulting in high oil consumption and/or a leaking Head Gasket has damaged the Catalytic Converter
Common Misdiagnoses
  • Oxygen Sensor(s) are replaced when the real problem is a damaged Catalyst
  • Catalyst is replaced when the real problem is internal engine damage, which is producing elevated emissions levels
  • Catalyst is replaced when a misfiring engine is the real problem
Old Oct 4, 2019 | 03:35 PM
daniel5455's Avatar
The code is P0442 Im sorry i wrote it wrong on the title.
Old Oct 4, 2019 | 03:48 PM
I went with that because I've never seen a serv stab sys failure with an evap leak?
Do you have any other codes? Does your scanner have trans capability?
Do you smell fuel walking around the truck after parked?
Old Oct 4, 2019 | 04:51 PM
daniel5455's Avatar
the Serv Stab error is gone but the p0442 is still showing. My scanner is an Innova 3040c not sure if it has that feature https://csr.innova.com/Content/Manua...wnloadable.pdf
I dont smell any fuel and truck drives fine.
Old Oct 4, 2019 | 05:52 PM
Did you check for ABS codes?
Old Oct 7, 2019 | 09:03 AM
daniel5455's Avatar
So i cleared all fault codes (P0442) and so far it has not shown up while driving over the weekend. Now the only issue is SYS STAB TRACTION FAILED will show up every once in a while. My scan tool doesnt show any issues related to this error.
Fambam
Aug 27, 2019 10:35 PM
happythree
Jan 1, 2018 09:51 PM
hakan
Dec 21, 2017 02:54 PM
crc2k
Jun 27, 2017 08:09 AM
mephis2012
May 4, 2015 10:21 PM
