H3 2006 Cylinder 4 Misfire CEL but runs perfect
Old Jun 19, 2024 | 08:07 PM
VinceH3's Avatar
Default H3 2006 Cylinder 4 Misfire CEL but runs perfect
I have a 2006 H3 that has a CEL for cylinder 4 misfire but it runs perfect. No issue idling, no issue driving/performance. I cant pass emissions with the CEL. Any input will be greatly appreciated. Thank you
Old Jun 20, 2024 | 09:52 AM
try switching the coil with another one of them and see if the code changes to that position.
Old Jun 20, 2024 | 01:28 PM
Welcome. MOVED to the H3 section where all H3 tech questions go.
Agreed, swap the location of #4 coil with any other and see if the misfire follows If it does, replace that coil pack. Also check the wiring to coil #4 for compromise.
Old Jun 20, 2024 | 04:31 PM
VinceH3's Avatar
Thank you for the response but I did all of the obvious things. I even changed the injector - nothing. Runs great but CEL for misfire
Old Jun 20, 2024 | 06:21 PM
it is an 06 hopefully its not a bad valve seat then.
Old Jun 21, 2024 | 08:18 AM
Happy Hummer's Avatar
U r using oem grade parts correct?
NO fancy sparkys right?
Oem grade c.o.p. and injectors?
Try running a 20 Oz. bottle of techron complete sys clnr. in gas tank.
Old Jun 21, 2024 | 09:27 AM
What are "the obvious things"? Did that including swapping the #4 coil pack with another? Tracing the #4 coil pack wiring for compromise?
Old Jun 21, 2024 | 04:59 PM
VinceH3's Avatar
I changed the coil packs and plugs. Pulled the intake and change 4 and 5 fuel injectors. The engine runs excellent. Speedo does not work and it is stuck in 1st gear. But for now I am just trying to get past the CEL.
When I pulled the intake the valve chambers and valves looked great.
Old Jun 21, 2024 | 05:34 PM
"Pulled the intake and change 4 and 5 fuel injectors" Why half-azzed when your're in there? I'm still driving my '07 with OEM factory installed fuel injectors and I don't have a misfire! However, I have 5 new oem fuel injectors for backup if I need to go in.
Old Jun 21, 2024 | 06:04 PM
