Got the error P0449/ wants to stall after starting.
Old Nov 3, 2020 | 05:35 PM
combines44's Avatar
Default Got the error P0449/ wants to stall after starting.
Hey...I have read a ton on this error code but not many say what their H3 does or how it acts. Mine when I start it wants to stall or close to it so it will stall sometimes and other times close to it. if I pump the gas a bit it seems to help fight it and after a minute she is running fine. Anyone else have this issue? what was your fix? I checked the gas cap and next onto the PCV hose then the vent solenoid. Is there a way to test the solenoid to see if it is working or not? TYIA!
Old Nov 3, 2020 | 06:39 PM
P0449(vent valve) will not affect engine performance. Any fuel smell walking around your H3? Any other codes when you scan?
Old Nov 4, 2020 | 09:08 AM
Year, Model and Miles when you ask any question. False stall is a different issue. When was the last time you cleaned your MAF with MAF cleaner and your Throttle Body with TB Cleaner?
Read this, do the list. Acts like it wants to stall/rough idle -No CEL -What To Do:
Old Nov 5, 2020 | 09:05 AM
combines44's Avatar
sorry...2006 h3 with 230000 kms.
never ever used either as my uncle is the mechanic. I figured it was the evap error issue??
Old Nov 11, 2020 | 08:11 AM
combines44's Avatar
yeah also P0300 comes up and I do smell fuel. Also during this hiccup the check engine light flashes on and off until the episode is over.
Old Nov 11, 2020 | 09:45 AM
RKSmith163's Avatar
I would guess a leaky Injector.
bureau13
Nov 19, 2020 09:10 PM
21LoLo21
Apr 10, 2017 11:10 AM
atari800
Nov 25, 2015 01:27 AM
mikabika
Oct 9, 2014 04:12 PM
italia147
Oct 31, 2010 10:05 PM
