Front drive line issue
Old Jul 17, 2021 | 08:45 AM
Here.for.beer's Avatar
Originally Posted by gpcalero
Another potential issue you will want to look at is the lower ball joints. I have found that the AC Delco Professional lower ball joints come with a zerk fitting that either touches or comes infinitely close to the cv boot. That could definitely cause some damage.
my issue lies with the cv joint on the drive shaft not the outer axle shafts.
Old Jul 17, 2021 | 01:57 PM
Dylan Rogers's Avatar
Originally Posted by Here.for.beer
So I have an 06 H3 with 123xxx miles. I’m having an issue with the front drive shaft. About a year or so ago the CV joint went out. I replaced just the joint. Then back in April I noticed the boot was torn and dry and beginning to make noise. I replaced it again. Yesterday I started hearing noise again so I looked under it and that boot is torn again. I grease the joint every time I’ve replaced it. What would cause these boots to keep tearing? At 194 bucks a crack I’m not too keen on replacing these things every few months.
thanks
If you still have the vehicle put together, can you post a video from outside the vehicle (helpful in hearing what the sound is). Also, does "the sound" get worse during any points of operation (like turning, full lock, going straight, etc.)?
Also, there are generic boots which can be fitted to replace our existing boots. They are pretty easy to replace but require a specific wrench to make it easy. If you entire axle assemblies are still good (aside from the boot), I suggest re-using the old assemblies.
Old Jul 18, 2021 | 04:46 PM
thanks
Cool so this is a forum of dicks who got nothing better to do but pull there dick and give useless answers. I’ll remember that. Thanks for your help cuck...
Your BS don't add up! I've had numerous customers in past 40yrs, that couldn't afford replacing the axle/cv joint, due to a torn boot. I always advised them to wait until you here a clicking noise, many lasted 20k+ miles or more, before clicking noise occurred. Grease doesn't washout with water! Meet Dick, Here.for.beer
user 956363738
Apr 22, 2022 01:23 PM
ski.dive
Feb 27, 2020 11:10 AM
soundguy
Feb 21, 2019 11:03 AM
Mkawas
Oct 6, 2017 10:09 AM
cspringsh3
Feb 21, 2007 10:37 PM
