Fault Code C0276 - fixed
Old Dec 20, 2021 | 06:32 PM
H3Manual's Avatar
Default Fault Code C0276 - fixed
Was getting error message for ABS/TC/4WD. Inspected connections-nothing. Pulled the TCCM & cleaned it inside & out. Reinstalled TCCM. The code is reset & has not come back (so far ~ 4weeks)
Old Dec 20, 2021 | 06:36 PM
Nice work!
Old Feb 9, 2023 | 12:43 PM
Ryson973$2??51@$$'s Avatar
Default code C0276
hey:
first time post. trying to clear up a couple of trouble codes on my 2006 Hummer H3. Getting a C0276 code. so, just a little background info- I had the vehicle front end aligned and later had the replace the lower steering shaft. (the knuckle was rusted out). after replacement the steering wheel would not line up with the original alignment. no biggy-the truck still ran straight-just the steering wheel was off center. will get fixed with another alignment. could I have done something to alter the SWPS (steering wheel position sensor) and throw a stabilization code? this is the only change i made and it popped up right after replacement? thank you.
Old Feb 9, 2023 | 07:57 PM
Originally Posted by Ryson973$2??51@$$
hey:
Old Feb 10, 2023 | 10:51 AM
OLD THREAD Alert. Skip the dig up old thread stuff an Post a NEW Tread with your new question. C0276s got nothin to do with steering shafts. READ: Old Threads/'Necro-Bumping'
Old Apr 1, 2023 | 12:28 PM
Sorry and thank you
ulthummer
Oct 11, 2021 11:23 AM
Indskys
Aug 3, 2020 03:14 PM
mephis2012
May 4, 2015 10:21 PM
GarbMan
Jun 4, 2012 04:33 PM
ALPHA XY
Apr 14, 2008 10:28 AM
