Engine Swap for base H3 (2009) ?
Old May 8, 2023 | 03:35 PM
FaygoDon's Avatar
Default Engine Swap for base H3 (2009) ?
I’ve got a 2009 H3 that I absolutely love. The only issue I have is the car feels like it’s lacking the power it should have. What engine can I throw in there? Base model only pushes around 240hp lmaooo.
Old May 8, 2023 | 06:55 PM
CAR??
My '07 H3 gets 242 hp @ 5,600 rpm- Torque 242 hp @ 4,600 rpm & 0-60mph in 8seconds.
H3 vs "CAR":
Old May 8, 2023 | 08:34 PM
Golden Hurricane's Avatar
Ouch!
Old May 8, 2023 | 08:54 PM
the fastest engine swap is an H3 alpha. it fits in the exact same spot as the H3 base.
Old May 9, 2023 | 01:52 AM
Disel's Avatar
[QUOTE=FaygoDon;400526]У меня есть H3 2009 года, который мне очень нравится. Единственная проблема, которая у меня есть, это то, что машине не хватает мощности, которую она должна иметь. Какой двигатель можно туда закинуть? Базовая модель развивает мощность всего около 240 л.с.[/QUOTE
Many install the Toyota 3UZ-FE engine. From Lexus engine with automatic transmission.
The most common SWAP engine in the world. There are many instructions for installing it.
Old May 9, 2023 | 01:31 PM
Mod what you have and learn how it works. You have a capable off road platform designed for LOW END Torque, not an open highway star.
My 07 with an Intake, Cat Back exhaust, PCM Tune, Efan Conversion, PP Throttle Body, aluminum radiator, in all its off road goodies could keep up with most FS V8s, and make some look silly.
You want a V8, sell yours, buy an Alpha. A swap is going to cost a fortune and will not be a turn key reliable ride that can be serviced by anybody.
Old May 9, 2023 | 05:53 PM
RVR's Avatar
RVR
Have you seen any of the posted swaps to the V8? Lotsa parts to swap, and it's expensive.
If it fit "in the exact same spot", you wouldn't need to change the differential and axle housings.
As Doc Olds posted, just "buy an Alpha", and get on with your life.
Old May 9, 2023 | 06:27 PM
no i was suggesting the entire vehicle not components. H3 alpha fits in the same parking spot as the H3 base.
Old May 10, 2023 | 06:18 AM
RVR's Avatar
RVR
Ah. Gotcha.
Old May 12, 2023 | 03:01 AM
Happy Hummer's Avatar
Yep, my H3 is slow, putzy but it has great low end torque for towing. It's gutless lol.
But I'm not messn with it.
Abdallah Hanna Moussa
Hummer H3T
Feb 1, 2023 06:57 AM
Davidburke
Hummer H3T
Dec 2, 2019 10:35 AM
hakan
21
Feb 26, 2018 08:48 AM
OUTLAW
Feb 15, 2008 07:25 AM
t.j.
Mar 18, 2007 12:24 PM
