Engine Start (Lack Of)
Old Feb 1, 2026 | 08:20 AM
Roar2025's Avatar
Default Engine Start (Lack Of)
Electrical system seems to be on (new battery) when trying to start - radio sounds, dash illuminates but no engine start not a sound from the engine.
What is not going on ?? Anyone experienced this issue? What is the solution ?
Old Feb 2, 2026 | 05:33 PM
Justinh's Avatar
You mean no sound from the engine or the starter? Check fuses and relays, then check wires. And most will say to replace your OEM battery terminals.
Need year and miles.
Old Feb 2, 2026 | 06:02 PM
Happy Hummer's Avatar
Being that your in the Frequently asked Questions area didnt even know you were looking for some help.
That being said.... Id start with verifying you have a solid, non corroded ground and +12.9v at your fuse box. Then check to make certain your getting power to the connection at your starter. Make certain that ground behind your air box is clean, tight and physically inspected...not just visually. Then head to the grounds nearest the EBCM ABS area and check the same applies. DON'T just visually inspect. You need to undo the grounds clean, check each one separately and then test with dvm set to continuity or ohms.
Old Feb 2, 2026 | 07:04 PM
Roar2025's Avatar
Default Hummer Locked
Thank you Justin for your response.
It is a 2008 H3 Alpha --- 55,520 miles.
I've read, through this forum, that I should check the DLIS fuse...excuse the ignorance... I'm not locating a DLIS fuse. Is it named something else ?
Old Feb 2, 2026 | 07:07 PM
Roar2025's Avatar
....yes, no sound from engine or starter.
Old Feb 3, 2026 | 09:50 AM
you probably need to put a test light on the starter solenoid as you crank. the signal wire coming from the ignition key at the starter if it lights up then your starter is toast if it does not then you need to verify and make sure the transmission range selector on the transmission (neutral switch) is in either park or neutral. the shift bushings do fail over time and it might be in limbo or wrong gear. last thing to check is if it has an aftermarket alarm or cut off switch or GPS tracker with an imobilizer.and sorting whatever can of worms that has introduced.
chaos06
Sep 19, 2022 07:00 PM
Thatsgr8
Apr 24, 2021 05:56 AM
559H3
Sep 8, 2020 08:59 AM
David Stanley
Nov 5, 2014 03:12 AM
wdreyfus
Jan 17, 2012 06:26 PM
