Engine Coolant Reservoir
Old Oct 6, 2020 | 03:05 PM
Alex DjFlaco's Avatar
Default Engine Coolant Reservoir
Hello everyone I checked my engine bay and saw my coolant reservoir level very low. I was thinking of running to autozone and purchase some coolant and I wanted to know which one I should suggest purchasing.
Old Oct 6, 2020 | 03:13 PM
Dex-Cool 50/50 premix is about as easy as it gets, already has water added, no mixing.
Old Oct 6, 2020 | 03:29 PM
thank you, does it matter which color of coolant I already have in there before I refill it?
Old Oct 6, 2020 | 06:21 PM
wpage's Avatar
Go for the mix...
Its recomended. Should match.
Old Oct 6, 2020 | 06:42 PM
I'd be more concerned as to where did the coolant go? I haven't lost a drip since '12, when I replaced the radiator with a cheap aftermarket.
Old Oct 6, 2020 | 06:51 PM
I'm going to fill it up again and see if it goes down.
Old Oct 6, 2020 | 07:02 PM
I recommend pressure check first, before you waste coolant.
Old Oct 6, 2020 | 07:13 PM
https://www.youtube.com/watch?v=jcEow4CC2ME
thank you im going to do that just to confirm everything.
Old Oct 6, 2020 | 07:21 PM
I'm going to take a proper picture of my coolant reservoir when the car engine is cold to see where the level is.
Old Oct 6, 2020 | 08:09 PM
Another member showed coolant level, I added an arrow to show where the coolant level should be:
