Easy fix for loose seatback nets!
Old Sep 2, 2019 | 07:33 PM
Originally Posted by Firedawg61
Replace the elastic. Only thing I know left to do...
Will not change a thing, the hooks are the issue, and need to be wedged/secured.
Old Sep 9, 2019 | 10:20 AM
I have done the tubing "fix" on every H3/H3T seatback we have owned since 2011.
Works every time and never an issue after.
Old Sep 16, 2019 | 06:39 AM
choochmalooch's Avatar
Cool Quick Fix
Here's a pic of a simple fix I did 5 yrs ago when I bought my H3. Totally forgot about it until this weekend. Just use a small black zip tie. Haven't had a problem since.
Old Sep 17, 2019 | 04:45 AM
wpage's Avatar
Question Cool...
Like what you did there...
Question. What size hole did you drill in the back plane?
Old Sep 17, 2019 | 06:36 AM
Cool
Off hand I don't remember but chose a bit that's just large enough to accommodate the size zip tie you are using.
Old Sep 17, 2019 | 07:56 AM
Broken Halo's Avatar
I used Christmas Tree Clips in the hole to keep the metal retainer in place. Locked in solid, but easy to pop the Christmas Tree Clip out if you want to remove. I actually have the 'back packs', not the 'nets', but same system on both. Also doesn't overstretch the elastic (as with the rubber tubing fix) which eventually will fatigue and you might end up with them loose again.
Picture without clip.
Picture with clip.
Old Sep 18, 2019 | 06:38 AM
Cool
The clips on my nets are not flexible and the holes are small. Not sure this would work but it looks like a good fix for your application. I have a huge assortment of thos clips and I'm always trying to find uses for them.
Old Sep 18, 2019 | 10:38 AM
Never a problem over 5yrs later.
8 pan head screws 1/2" long, wedged against the hooks when installing the screws and they don't move at all.
Old Sep 19, 2019 | 07:06 AM
Cool
Looks good but I like my zip ties, less obvious.
Old Sep 20, 2019 | 05:53 AM
wpage's Avatar
Both these solutions are great. I copied both tinding the ties worked nice on the upper connections.
However, on the bottom connectors screws are easier then fishing the zip ties thru the holes.
Thanks to both of you for the creative ideas to solve the problem of seat back storage fall outs.
