DRL's + headlights simultaneously..?
Old Sep 22, 2022 | 10:09 AM
  #91
legerwn's Avatar
I tapped into the power side of the headlight fuses so the extra load of the DRL's don't add to the load on the headlight fuse,
Neal
  #92
Tonman316's Avatar
Default Thanks, yes mine is also a 2008.
Originally Posted by legerwn
I tapped into the hi and low beam headlight fuses with the pink terminals and then the blue terminal is the DRL fuse.
My H2 is a 2008 and can get you the fuse numbers but if yours is not an 08 they may not match,
Neal
hi Neal, mine is also a 2008 and I couldn’t find any other detailed pictures like yours for the 08-09 models. Thanks for your help. 👍🏼
Old Sep 22, 2022 | 10:22 AM
  #93
legerwn's Avatar
The fuses I tapped into are number 14 Right Low-Beam Headlamp, 25 Right Side High-Beam Headlamp, 26 Daytime Running Lamps (DRL)
Neal
Old Sep 23, 2022 | 01:35 PM
  #94
Larry150's Avatar
Default Hummer Door Panels Retainers that work great
Originally Posted by Ta Jay
I would like to have them both run at the same time. any secret way of doing this?
J
If you ever need any door panel clips. Check out the 956store.com..they have some that really fit well
Hummer door panel retainers
H2 Hummer door panel clips
W1N
Mar 29, 2019 04:20 PM
happythree
Apr 8, 2016 04:34 PM
NJTEX
Dec 11, 2014 10:02 AM
dwilton
Dec 15, 2012 09:37 AM
slateblueh3
Apr 19, 2012 08:47 PM
