Drip front axel 2006 h3
Old Aug 27, 2025 | 10:43 AM
wpage's Avatar
Default Drip front axel 2006 h3
Hey folks,
So getting a slow drip for a while. Tried a few clams. No help.
Any experience
on what to do?
Old Aug 27, 2025 | 01:34 PM
Yep, it is wet. Looks like driver side? The drips do not come from the half shaft, they come from the front Diff ... or through the Axle Shaft Tube Differential Housing Support on the driver side like yours. You might need a front Axle Shaft Seal. The ACDelco version is getting hard to find and is discontinued, but others make them. Like $22 +/- When was the last time the front diff fluid was changed?
I would start with easy stuff, remove your clamps, they are doing nothing except effecting balance of the half shaft. On a level surface check the front diff fluid level. Biggest cause of diff leaks is............ OVER FILLING. You could even add some stop leak if the level is low to see if that buys you some time before doing a replacement seal.
Old Aug 27, 2025 | 01:38 PM
#3 on the diagram below is the seal
Old Aug 27, 2025 | 02:25 PM
Old Aug 28, 2025 | 03:16 AM
wpage's Avatar
Hey Doc Olds and bronxteck.
Thanks for those excellent tips... I did change the front dif recently. Which may account to overfill and dripping. The clamps are coming off today.
The AT-205 looks interesting. Easier than pulling it off and possibly mess it worse. After 20 years and 115k on the OD a little dripping on the garage floor is not a biggie.
Bigguy214
Aug 3, 2025 05:46 PM
Mutasim
Nov 16, 2024 12:45 AM
montana53
Aug 23, 2023 01:09 PM
H32006
27
Oct 19, 2012 12:46 PM
Kels3770
Sep 25, 2007 07:04 AM
