Roof rack help please!!
Try This:
At the end of the guide rail at the top of the vehicle, closest to the red trim roof light, is an end cap with a spring clip. Using your finger or small flat tip screw driver, you can flex the clip forward and use the small round hole to lift the end cap off. This should work.
Once the end cap is off, you can loosen the cross bars and slide to the back and remove. You'll probably need another set of hands to help move the rail the rear so it stays parallel and doesn't pinch.
lmilli1
04-27-2014 10:44 AM
Caraddict
33
11-12-2012 07:47 AM
DennyOK
10-31-2012 11:01 AM
Caraddict
04-22-2011 07:13 AM
FloridaFeMan
20
02-18-2010 08:19 AM
