Door switch illumination
Old Mar 28, 2025 | 03:26 AM
alssiri's Avatar
Default Door switch illumination
👋 Hi , I have all my door switches working fine but have no illumination lights 😕 changed the bulbs & still not working .
is there a wire or fuse that I need to check ?
Ahmad
Old Mar 28, 2025 | 09:12 AM
Welcome to HF.
If you used LED Bulbs, they are polarity sensitive so they may need to be rotated 180 degrees. Or, they are not making full contact with the board. What specific bulbs did you use?
Somebody else that did the bulb replacement that had issues and overcame them will stop by and offer some assistance.
Old Mar 28, 2025 | 09:21 AM
alssiri's Avatar
Welcome to HF.
😊 thanks for the reply, yes i did rotate them but same issue even with stock bulbs nothing works on all of the switches.
I used the same led in the ac control & the worked fine , that's why i asked if there is any wire or fuse need to be checked.
Ahmad
Old Mar 28, 2025 | 10:51 AM
Broken Halo's Avatar
There's always going to be fuse, or circuit breaker, feeding electrical circuits. Pop the hood, pull the cover off the fuse box, look at the underside and find the correct one for the interior lighting, (or look in the owner's manual).
Old Mar 28, 2025 | 03:36 PM
Old Mar 28, 2025 | 03:57 PM
alssiri's Avatar
This button is for the curtesy lights .
Old Mar 28, 2025 | 04:20 PM
What "no illumination lights" are you referring to?
Old Mar 28, 2025 | 04:29 PM
alssiri's Avatar
Ahmad
the door switches are working but doesn't have illumination.
Old Mar 28, 2025 | 05:00 PM
Does the Ambient Light Sensor work?GM Part # 15174892
Old Mar 28, 2025 | 07:01 PM
alssiri's Avatar
I think it is ok cause all dash & ac control light are working.
