Does injectors need reprogramming after replacement?
Old Nov 6, 2019 | 09:39 AM
Alibou's Avatar
Default Does injectors need reprogramming after replacement?
If yes what diagnostic tools are required?
Old Nov 6, 2019 | 11:33 PM
Happy Hummer's Avatar
None that I'm aware of.
Old Nov 7, 2019 | 11:40 AM
Plug and play. They does not.
Old Nov 7, 2019 | 12:25 PM
it would only need programming if you change the size of the injector for anything other then the stock size.
Old Nov 7, 2019 | 12:42 PM
Alibou's Avatar
Thanks for the reply.
I order GM OEM injectors , so hummer H3 doesnt need reprogramming injectors if OEM.
That's what I found in some forums, some old cars dont need it
Common rail Injector coding | techtalk.ie
Old Nov 7, 2019 | 01:20 PM
correct.
stock OEM is direct swap no programming required. Usually GDI engines might need programming which these are not.
Old Nov 7, 2019 | 02:26 PM
Alibou's Avatar
correct.
I had a bad batch of gas I guess and was running on fumes, started badly misfiring = barely drivable.
Siphoned gas tank and put premium gas seems to have fixed it for a 10 miles test.
If not I replace injectors.
Thank you
I will keep you posted.
Ps: can a faulty valve give intermittent problem?
Old Nov 7, 2019 | 03:13 PM
what valve?
Old Nov 7, 2019 | 03:20 PM
Alibou's Avatar
what valve?
If a Valve seat problem can it be intermittent or is it permanent?
Old Nov 7, 2019 | 03:22 PM
it can depend how loose it is.
