Diesel conversion for H3
Old Sep 5, 2016 | 06:29 PM
Dave71's Avatar
Default Diesel conversion for H3
The other day my stock engine took a complete dump. And thinking about swapping the stock for a diesel. First question is there a diesel engine that will bolt up to the trans and wondering who had this done,who did it themself. Do's and don't and is it worth it.
Thanks for any and all comments
Old Sep 6, 2016 | 07:00 AM
There is only 1 I know of and it was a ton of work with custom parts etc.
I believe he used 4BT.
Old Sep 6, 2016 | 03:00 PM
Nope and nope.
There would be no swapping, more like complete adaptation and fabrication. You would be the second guy on the planet to try it, and who knows how it would turn out after a butt-load of work.
Old Mar 8, 2017 | 03:17 PM
CaseyS's Avatar
Nope and nope.
Its worth it. I just realized there may be a few of you here that haven't seen this linked on other boards.
Old Mar 17, 2017 | 02:59 PM
FatJay's Avatar
Sounds like the user would have to have a considerable amount of know-how. Does the engine match the bellhousing, or does the trans go with it and it is shaft back?
Anything is possible, practical is a whole different story.
Old Apr 5, 2019 | 09:04 AM
moto1969's Avatar
Default Sawpping h3 engine for a diesel?
Need more info? Is there a link to on this image of an successful swap? Thanks
Old Apr 5, 2019 | 09:23 AM
Ahhhh, the bump of a TWO YEAR OLD Thread to ask if there is a link with the picture posted by a guy that last stopped by here 2 years ago.
Old Apr 5, 2019 | 09:46 AM
CaseyS's Avatar
https://www.4btswaps.com/forum/showt...s/27760?page=1
Build thread here. Couple of hours worth of reading to digest.
Old Jan 15, 2022 | 10:47 PM
Jeremy Smith's Avatar
Default Fule pump
Attachment 10876
I'm in the middle of the same swap. What did you do for fule pump and set up?
Old Jan 17, 2022 | 08:36 AM
CaseyS's Avatar
Just use the mechanical pump located on the block and run a suction line into the tank. You will want to remove the filter sock on the existing line in the fuel pump basket if you choose to re-purpose part of that assembly for the suction line.
BrazilianHummerMan
Sep 1, 2021 08:22 PM
FoxHummer
Mar 22, 2013 11:23 PM
Panzerh2
Jul 1, 2012 03:13 PM
pimpedlude
Sep 8, 2010 12:13 PM
