Crankshaft Removal Interruptance
Old Oct 7, 2019 | 04:52 AM
RVR's Avatar
RVR
Default Crankshaft Removal Interruptance
I was just about to remove the crank from my '08 H3 3.7L when I removed the rear plate from the block and discovered the mini timing chain driving two small sprockets from one on the crank. All three have alignment marks, so I spun the crank to TDC on piston #1, but the marks are all over the place.
Since the cams are driven and timed by the front timing chain, is it a case of these sprockets merely having the marks from the manufacturer, but there is no timing alignment involved ? I'm not sure what both sprockets are even driving.
Old Oct 7, 2019 | 08:51 AM
Crispins's Avatar
I do not have any specific experience with our motor but generally what you have there is 2 balance shafts.
The timing marks will only realign every 130 something rotations.
Typically you just set all the marks correctly to their mating marks during reassembly and you will be fine.
However, I have seen motors where that will allow the balance to be 180 degrees out for some reason.
You are going to need to get a hold of a service manual if you want to be 100% certain on the procedure
Old Oct 7, 2019 | 11:23 AM
RVR's Avatar
RVR
The two driven sprockets are not symmetrical. One drives a shaft down the side, which could then drive the balance shafts (completely forgot about those). The other is at the bottom and drives a set of worm gears. The balance shafts would definitely need to be timed.
Old Oct 7, 2019 | 04:47 PM
DJB's Avatar
DJB
Replaced mine last year. Definitely timed. The wear was so bad that you could hear the chain links rubbing on the tensioner mounting plate. I belive that the marks are aligned only on every seventh rotation. Get the timing wrong and you'll have a 4900 pound vibrator.
Old Oct 7, 2019 | 11:35 PM
RVR's Avatar
RVR
Update:
First, Crispins you were correct sir ! The two sprockets are driving the two balance shafts, with one also driving a set of worm gears, which I suspect is the oil pump.
Second, the timing marks on the three sprockets need to be at noon, 2:30, and 4:30. Yikes. Also, the three black links in the chain have to match those same marks, and that only occurs every eleven rotations.
Hands down the wackiest engine I've ever rebuilt. Well, the crank is at the machine shop.
Jim_Davis
Feb 17, 2021 09:09 AM
frankp
Apr 17, 2019 01:44 PM
Donald Austin
Aug 29, 2018 12:39 PM
MeBelovinMyH3
Jul 14, 2014 11:02 AM
hangout
Sep 15, 2012 08:15 PM
