Cooling issue
Old Aug 26, 2019 | 05:32 AM
Grantles's Avatar
Default Cooling issue
Hey guys
have a 2007 h3 hummer luxury
had the trans cooler blow in the radiator so it’s been
replaced now has an external cooler has new radiator, thermostat and cooling temp sensor. Engine light keeps coming with code p0128 which is running too cold, also the bottom radiator hose won’t heat up. Any ideas what it
could be.
Old Aug 26, 2019 | 11:28 AM
Welcome to HF. H3 questions all go in the H3 section.
I see you stated the Thermostat was replaced, but did you do the work? Your problem is the TStat is likely stuck open. Either it is defective, not installed correctly, or whoever did the wok put in the old one or none.
Have you checked your coolant level after the repairs?
Old Aug 26, 2019 | 03:43 PM
Air in the coolant system. Make sure to properly bleed all the air out before you install the radiator cap.
Old Aug 26, 2019 | 04:20 PM
Grantles's Avatar
Will get another thermostat under warranty from mates shop who did the job and see if that fixes the problem,
thanks
Old Aug 26, 2019 | 06:15 PM
thanks
You came here for DIY advice, and have a shop doing the work?
FIND A DIFFERENT SHOP!
or you could tell your "mates shop" to flush the coolant system and bleed all the air from the coolant system.
Diy Flush:
Old Sep 3, 2019 | 06:16 PM
wpage's Avatar
Does sound like the thermostat is stuck open or possibly left off if its running that cool.
Coloh2hummer
Apr 14, 2018 03:24 PM
Johnny B. Epic
Feb 21, 2012 03:04 PM
melloyello
Apr 6, 2011 10:55 AM
swenski71
Sep 20, 2010 10:31 PM
c3 rolling
Jan 23, 2009 12:50 PM
