04 hummer 2 overheating?????
Old Mar 20, 2018 | 05:03 PM
Coloh2hummer's Avatar
Default 04 hummer 2 overheating?????
i have replaced the thermostat so, now where? Could it be the radiator clogged, should I back flush it? Also, the hummer doesn't have the trans cooler mod, is that something I should consider? Someone was saying to unclog the remote radiator tank???
Old Mar 20, 2018 | 08:30 PM
hummer_on_fumes's Avatar
The obvious thing to check is the coolant level. That will tell you if your radiator is leaking somewhere. Is the engine or trans overheating? Yes you should definitely put in a separate trans cooler. The oem radiator is a ticking time bomb to destroy your transmission when the fluids mix
Old Mar 20, 2018 | 09:56 PM
Ok, the trans temp gage is broken. I have checked the coolant numerous times and it hasent changed. Eng temp gage will go full hot if you keep going, I pulled over and turned the eng off. I checked the eng temp with an infrared temp checker and the gage is spot on! I guess I could check the trans temp with the infrared?
Old Mar 21, 2018 | 07:58 AM
calif phil's Avatar
What's the mileage? If over 100,000 I would buy a new quality radiator.
Old Mar 23, 2018 | 10:31 AM
tharber's Avatar
It could be anything from a bad water pump, bad radiator or bad gauge.
Tim
Old Apr 14, 2018 | 03:24 PM
Dry Heat's Avatar
It could be something else. Mine started overheating and went in creep mode. I found out the catalectic converter had gone bad and the whole system was shutting down.
man-of-war
Jun 25, 2013 11:26 AM
rax282
Mar 2, 2009 12:21 AM
c3 rolling
Nov 6, 2008 08:07 AM
cgnd3000
25
Jun 20, 2007 12:05 AM
Guy
Apr 25, 2007 04:50 AM
