Code P0716 and P0717 Input speed Sensor
Old Feb 12, 2012 | 10:29 AM
drtom's Avatar
Banned
lol looking for repair manuals at 2:45 am?!?!? What are you doing lol
24 hours in a day, im delighted that i can choose how i use them and mind my own business!! while helping someone else.
its great to be able to sleep from 9 to 5 if i choose, and to choose which 9 to 5 i want!
dracula did his best work after dark, slept all darn day
Old Apr 6, 2012 | 04:55 PM
mtauseefsa's Avatar
Quote:
Originally Posted by olson0099cody
I recently got that code also the p0717. i took it in and got it looked at. What did you end up doing? Any advice on what i should do? how did you fix your problem. i have a 2007 h3 3.7L. please email me *******@hotmail.com as its easier than on this site.
Cheers,
Cody.
MY advice, get it rebuild and replace the input speed sensor. It cannot be replaced until you open up the whole gear box. It is located behind the flywheel.
I first created a circuit board to amplify signals. It took me one day to create the circuit, then 3 days to find this speed sensor wire in PCM. Once i hook it up, it works for a moth. Then one more circuit to be build. Finally i spent money and get it rebuild.
Old Jun 19, 2012 | 09:05 AM
Gregory's Avatar
Default Codes P0300 and P0717
2007 H3X.
Had oil changed and tires rotated before using for a road trip. At some point during the trip, the check engine light and rough shifting (automatic transmission) started. Had the codes pulled and I have both codes P0300 and P0717 locked in. I was wondering if it could be another problem leading to those two codes? The multiple misfires and the input speed sensor codes at the same time is leading me to believe that something else is causing them. Any ideas?
fastlap
Jul 5, 2014 07:09 PM
Alex2012
Apr 22, 2013 04:18 AM
scubasteve1211
Apr 2, 2012 09:09 PM
bheff
Jun 24, 2011 08:41 PM
Bohomit
18
Oct 27, 2008 11:46 PM
