code p0449
Old Aug 17, 2020 | 03:49 PM
Petryllama23's Avatar
Default code p0449
https://www.hummerforums.com/forum/h...e-valve-42601/
ive searched the threads to find anything recent on this code but last i seen was from january....
so here's to a new thread.
so here's what i have, 2006 hummer h3 161,122 miles
the only code i am reading is the p0449 evaporations code
but my vehicle continues to go in and out of "reduced power" "traction failed"
the reduced power seems to occur more often in the morning that in the evenings, its not cold yet here in the mornings typically 60 degrees when i start it up and 80-85 in the eveining
its not making sence as to why it will randomly kick into reduced power more often in the mornings than later in the day?
also the check engine light stays on, it is not an intermittent lite
has anyone had these two issues pertaining to each other?
any help is greatly appreciated
thanks
-Cole
Old Aug 17, 2020 | 04:01 PM
Get a better scanner! In the meantime, replace the vent valve.
Old Aug 17, 2020 | 05:16 PM
Happy Hummer's Avatar
Old Aug 17, 2020 | 05:24 PM
i will defiantly get on changing this part, i guess I'm just more curious to see if anyone has had the 2 issues come together as i am
the reduced power with this code?
thanks for the link
Old Aug 17, 2020 | 06:13 PM
Get a better scanner! Then you will find more codes related to your issue.
Old Aug 17, 2020 | 06:25 PM
Old Aug 17, 2020 | 06:32 PM
Originally Posted by Petryllama23
Just show me ALL the codes, for further advice!
Old Aug 17, 2020 | 06:37 PM
Try this one to pull the codes:
You have an '06. a scanner is always useful, to help you diagnose.
Here's one, with SRS too, under $100: https://www.amazon.com/gp/product/B0...69ad7fdd2be448
Old Aug 18, 2020 | 08:13 AM
Wait........................... no one mentioned.........................
Do you still have the crappy azzed OEM Battery Terminal Connectors? If so, hack them off and replace with a quality aftermarket set like Stingers or your favorite brand. Inconsistent poor battery connections can cause reduced power and traction failed messages, as can a bad connection at the Throttle Body or Accelerator pedal and T Case shift actuator respectively.
Indskys
Aug 3, 2020 03:14 PM
happythree
Jan 1, 2018 09:51 PM
pikappapp
Dec 24, 2017 12:19 PM
hummermongolia
Oct 4, 2015 07:55 PM
mephis2012
May 4, 2015 10:21 PM
