Instrument cluster recommendations
Old Oct 22, 2019 | 04:12 PM
yup that's definitely better... is that EAGLE?
Old Oct 22, 2019 | 07:17 PM
oceanbrave's Avatar
Altium Designer
Old Oct 23, 2019 | 09:16 AM
clsimmon's Avatar
That's incredibly impressive. So you just took every chip on the board and re-traced each circuit to figure out how it all works, or is there some kind of x-ray machine that does all of it for you?
Old Oct 23, 2019 | 02:11 PM
oceanbrave's Avatar
Alas no x-ray, if only it were that easy!
This was the procedure:-
  1. As the module was encased in rubber compound to seal it from the elements, carefully remove every molecule from beween the pins and surface mount components (you can still see some rubber-bits)
  2. Label and identify all SMT components and chips.
  3. Trace every track removing chips when necessary.
  4. Produce circuit diagram and verify.
  5. Produce PCB layout.
  6. Repair PCB & test (you can see the replacement track, my module had a hair-line fracture on the otherside)
Old Oct 23, 2019 | 03:43 PM
is the board dual layer or multi layer?
Old Oct 23, 2019 | 08:34 PM
legerwn's Avatar
I've used Digital-Dash-Solutions, LLC (fixmygauges.com) a few times, always good to work with and no issues with the quality of the clusters
Neal
Old Oct 24, 2019 | 05:09 AM
oceanbrave's Avatar
The original was double-layer plated-through, the one I created would be 4-layer but will never be manufactured so doesn't matter.
Old Oct 24, 2019 | 10:41 AM
we should have posted all of this at the other corresponding suspension thread it will probably get lost in this cluster thread
Old Feb 3, 2021 | 02:02 AM
majj35's Avatar
Hello, I have a 2004 H2 and recently had electrical issues with the Speedo instrument. The dealership said that I have to replace the whole instrument. They need to order the part from the US, which might take 1-3 months according to them (located in Saudi Arabia).
I asked for the part number to try to find it online to order but all searches show "Discontinued". This is the Part number they provided me with: 15134729.
The gauge I have is the "White" version in KMH. I don't mind getting a MPH, but need to know which other Part # would fit. Dealership can't confirm other part #, and I'm liable for any part I order myself. I found this Part # on eBay, 15199643 would this work? (eBay Link)
any other suggestions? Thank you
This is my current cluster:
Old Feb 3, 2021 | 08:19 AM
clsimmon's Avatar
There are several companies that refurb these clusters including Digital-Dash-Solutions, LLC noted above. Many still have parts and support from the original vendors of the components. My recommendation is that you send them a private message on ebay and explain what's wrong with yours and what you need. I'm certain they will be able to get you taken care of and probably even allow fo you to keep your KM/h which is pretty cool! I wouldn't abandon it as it's rare.
crum55
Jan 31, 2024 12:33 PM
oceanbrave
Aug 21, 2020 07:32 PM
RAHF
Oct 29, 2014 01:37 PM
SafariHummerH2
Jan 15, 2009 03:08 PM
humbug
Dec 2, 2007 08:02 PM
