camshaft Position sensor replaced, still a problem
Old Sep 12, 2018 | 02:36 PM
Donald Austin's Avatar
Default camshaft Position sensor replaced, still a problem
I replaced the camshaft position sensor on a Hummer 3 2006 (5 cylinder) after the code P0340 came up and it has problems with starting. Sometimes it starts right away and sometimes it will not. So I'm trying to figure out what to do next...maybe replace the crankshaft position sensor?
Does anyone have any recommendations?
Old Sep 13, 2018 | 03:47 AM
Happy Hummer's Avatar
Hard starting or no start Rough running / misfiring Loss of engine power Causes A code P0340 could mean one or more of the following has happened: a wire or connector in the circuit could be grounded/shorted/broken the camshaft position sensor may have failed the PCM may have failed there exists an open circuit the crankshaft position sensor may have failed.
Possible Solutions With a P0340 OBD-II trouble code, diagnosis can be tricky at times. Here are some things to try: Visually inspect all the wiring and connectors in the circuit Check for continuity in the circuit wiring Check the operation (voltage) of the camshaft position sensor Replace the camshaft position sensor as required Check the crankshaft position circuit as well Replace circuit wiring and/or connectors as required Diagnose/replace the PCM as required
Old Sep 15, 2018 | 05:21 PM
I replaced the intake camshaft postion sensor, called on star, p0340 no longer comes up, but now, p0366 comes up. i guess i replace the sensor in the rear of engine.... check wires etc...
Ernes Isakagić
May 24, 2016 02:09 PM
Raffi76
Mar 11, 2015 02:05 PM
ezekielj007
Aug 20, 2014 07:32 AM
powerboat
Jun 26, 2012 09:06 AM
keystone
Sep 15, 2009 01:17 PM
