cam position sensor 2010 h3 3.7L
Old Oct 28, 2021 | 02:58 PM
frankp's Avatar
Default cam position sensor 2010 h3 3.7L
does the 3.7 have one or two cps ? i can find one on front of engine passenger side.
the searching i've done shows two but on 3.5 L motors.
i'm not talking about theVVT SOLENOID/ACTUATOR but the cam sensors.
thank you very much
Old Oct 28, 2021 | 03:22 PM
All the I5s have TWO camshafts. How could one sense both? 3.7L CPS #s 703 & 710
Old Oct 28, 2021 | 05:02 PM
frankp's Avatar
my 2010 does not have a cam position located at #710
Old Oct 28, 2021 | 05:19 PM
frankp's Avatar
Default no cam sensor on in take side
no cam sensor intake side only exhaust side of motor
Old Oct 28, 2021 | 06:08 PM
My '07 LLR has 2 cmp's (intake & exhaust). Not long after my H3 was assembled, GM filed for Chapter 11 reorganization, therefore could not afford 2 camshaft position sensors on the LLR 2008-2010. You only get the exhaust sensor. Live with it!
Old Oct 28, 2021 | 06:23 PM
frankp's Avatar
Default it has always run fine and still does but 0017 code
thank you hummerz i guess doc should have never answered my post
Old Oct 28, 2021 | 06:49 PM
Originally Posted by frankp
thank you hummerz
Why hide your code? Look here--->P0017
Old Oct 28, 2021 | 07:05 PM
frankp's Avatar
Default 0017
had 0017 last year hummer ran fine ,some one on this forum suggested changing oil & filter so i did.
was 5K from last change 5-30 syn. had to erase code for 3 days but finally 'went away' untill yesterday.
hummer has 112K miles
Old Oct 28, 2021 | 07:19 PM
Pull the 12615873 and inspect!
Old Oct 28, 2021 | 07:32 PM
frankp's Avatar
Default 0017
actually did that yesterday no screens missing , not dirty but blasted with carb cleaner anyways-wife texted when she got to work this am that ck engine lite on again.
that is why i wanted info on cmp locations
