Bumped a fence post, wont start Please help
Old Mar 30, 2020 | 03:51 PM
jfitz's Avatar
Default Bumped a fence post, wont start Please help
My daughter backed into a fence post and now it wont even crank. If i disconnect the battery and reconnect it, it will crank but not turn over. If i try again it wont even crank. I checked the fuel pressure and its fine. Any ideas?
Old Mar 30, 2020 | 04:38 PM
jfitz's Avatar
Its a 07 h3 with 3.7L
Old Mar 31, 2020 | 09:32 AM
Are you still using the crappy azzed OEM Battery Terminal Connectors???? Been a bazillion posts on hacking them off and replacing with a quality aftermarket set to achieve a secure ans consistent battery connection.
BTW.... when you crank a vehicle it means it IS turning over.
Voltage of battery at rest?
Is the little lock symbol light up on the dash when trying to start it? If so, look up GM Passlock.
Old Mar 31, 2020 | 12:36 PM
Happy Hummer's Avatar
Did you may be end up shorting the wiring by the back bumper?
Old Mar 31, 2020 | 06:59 PM
jfitz's Avatar
Thanks for the replies, i do need to change the terminals. I found the problem. A while back i tried a cold air intake. I ended up removing it and evidently i missed a sleeve. When she was backing she got scared and missed the brake and slammed the gas instead. When she floored the gas that sleeve got sucked into the throttle body and stuck the throttle open. So when i tried to start it, the system knew the throttle position was wrong and kept it from starting. Its running fine now
Old Mar 31, 2020 | 07:38 PM
jfitz's Avatar
Old Apr 1, 2020 | 06:21 PM
Justinh's Avatar
Just when you think you've heard it all...
Old Apr 1, 2020 | 06:33 PM
wpage's Avatar
That will go down in the annals of H3 History...
I did fall for the suggestion of the short in the hitch wire harness. That was a good one...
Old Apr 1, 2020 | 11:04 PM
atkins4960
Jan 6, 2022 10:12 AM
simota1
Nov 24, 2021 12:45 PM
jchummer
Dec 28, 2012 06:08 PM
jfoulker
Apr 6, 2011 12:17 AM
Sugardaddy
18
Mar 17, 2007 05:47 PM
