Bling Bling Meets Offroad
Old May 27, 2006 | 03:30 PM
  #31
nascar 17's Avatar
Default RE: Bling Bling Meets Offroad
315 75 16 10 ply rated at e rating
Old May 27, 2006 | 04:29 PM
  #32
dilo2001gt's Avatar
Thanks guys
Old May 27, 2006 | 04:30 PM
  #33
dilo2001gt's Avatar
Black H3 how does it ride
Old May 27, 2006 | 04:42 PM
  #34
dilo2001gt's Avatar
what you think about these tire im not looking for mud tires
Terra Grappler AT
A perfect compliment to larger trucks and SUV's.
LT315/75R16D2 121Q B
Reading the Tire Size
$165.00 ea.
(Start a New Search)
No Mileage Warranty Available
Specifications:
Treadwear: 420
Traction: A
Temperature: A
Speed Rating: QR
Show me:
• Comparable Tires
Tire View: 3/4 ViewTreadShoulder
Large Image (1001 x 1001)
Stock Status per Distribution Center
Arizona Nevada Ohio Texas
Good Good On Order Good
The Terra Grappler A/T is Nitto's first light truck/sport utility tire to be offered in D- and E- load ratings.
•An aggressive tread pattern with high-density siping provides excellent traction and handling in snow and slush.
•Two steel belts ensure optimum contact patch both on and off the road.
•Two spiral wound nylon cap plies enhance high-speed stability
Old May 27, 2006 | 06:14 PM
  #35
BlackH3CA's Avatar
It rides great.....The terra's are alot cheeper then these toyo's.
Old May 27, 2006 | 09:04 PM
  #36
nascar 17's Avatar
please keep in mind that the nitto will not last very long. i have some friends who did rotate them regularly and only got 20.000 miles on them. it is a soft tire. it does look very coool and is a good tire it just wont get you high mile. if you want to check on it call any discount tire store or les swab and they will confirm this.
Old May 27, 2006 | 11:44 PM
  #37
dilo2001gt's Avatar
thank so the best one out there right now our the toyo's
Old May 27, 2006 | 11:58 PM
  #38
dilo2001gt's Avatar
WHAT ABOUT THESE THERE WEB SITE SAY BUY 3 GET ONE FREE ON ANY PRO COMP
OR STICK WITH TOYO'S
Product Detail
PRO COMP X-TERRAIN 315/75R16/D (35/12.50R16)
MSRP: $279.99
Your Price: $203.99
Pro Comp XTerrain Tires
The Pro Comp Xterrain's high void directional tread pattern takes over where other directional tires leave off. The Xterrain's extra thick side wall treatment helps resist scrapes and cuts, maximize a biting edge side wall for increased traction on rocks or in mud. Dualguard TM Polyester Body Plies consist of thick 2 ply polyester construction combined with a blend of dual side wall rubber allowing for maximum puncture resistance with total flexibility when using lower air pressure off road without excessive heat build up. These are fast becoming one of the most popular tires on the road today. Available now in 17 & 18†rim sizes too!
Pro Comp XTerrain Specifications:
High void directional/staggered/grooved tread pattern
Full length lug sipes
Alternating open lug shoulder
Extra thick side wall
Dualguard Polyester Body; 2-Ply w/dual side wall rubber
Two layers of opposed-angle steel belting
Black sidewall lettering
Image(s) shown are typical and may very depending on tire size
Old May 28, 2006 | 12:00 AM
  #39
dilo2001gt's Avatar
Pro Comp Radial All Terrain
Features a 50,000 MILE TREADWEAR WARRANTY. Pro Comp's new All Terrain tread technology encompasses many features to achieve the new "Severe Weather" approval rating required by many states for use in snow without chains. Dual compound rubber and computer designed tread pattern prolongs the life of the tire for an incredible 5000 mile treadwear warranty! Dualguard TM sidewall construction resists sidewall punctures, cuts and scrapes. All sizes come with raised white letters.
Radial All Terrain Specifications:
Severe Weather Rated; 50,000 mile warranty
Two layers of opposed-angle steel belting spans the tread area for maximum puncture resistance and flexibility
Staggered directionally grooved tread pattern has full length lug sipes for superior on or off road traction
Extra thick side wall treatment helps resist scrapes and cuts, maximizes a biting edge side wall for increased traction
Alternating open lug shoulder grip spurs aid in increased traction and self-cleaning
Old May 28, 2006 | 10:20 PM
  #40
jamesh3's Avatar
Whoa! I like it - gives me something to work toward.
NashvilleLimo
Jun 17, 2010 09:17 AM
Patrick
Meets, Events, and Shows
Apr 8, 2008 09:46 AM
HingHum
27
Feb 7, 2008 09:22 AM
importkiller
Sep 10, 2006 06:01 AM
