Battery drain h3 2007
Old Sep 10, 2014 | 03:11 PM
h3puertorico's Avatar
Default Battery drain h3 2007
Greetings:
My H3 (2007) is draining the battery (New Bosch. The batteryis ok.). If I don’t use it for, say, 2 or 3 days, battery goes from full chargeto 12.25 volts (aprox). I disconnected literally everything: Radio, alarm,etc., and it helped just a little bit, but the problem persisted. So I took itto a friend of mine who used to work for an electromechanic (I don’t know ifthis is the right word in English, but I mean the mechanic who specializes inelectric stuff, like alternators, batteries, charging system…), and he told methe problem is a module, most probably the “body control module”, and that thisis a common problem of H3s, Colorados, and other GMC trucks.
Have any of you experienced such a problem?
If so, is it possible to repair the module, or will I needto buy a new one?
Thanks.
Old Sep 10, 2014 | 04:52 PM
stubbsy's Avatar
I have the same thing with my 2007, if I don't drive for two weeks battery is flat, I now use a trickle charger when the vehicle is not being used. I also only get two years out of a battery.
Old Sep 10, 2014 | 04:54 PM
Not a BCM failure, it is a circuit that the BCM controls(lights, locks, windows, alarms, accessories, aux power, etc..). GL
Old Sep 10, 2014 | 06:21 PM
And how can it be detected?
Is it a short?
Can I detect the exact problematic circuit myself, using a voltmeter or something else?
Thanks.
BTW: In the meanwhile, what I am doing is disconnecting the negative from the battery when I get home. But that's tiresome.
I forgot, in addition to the aforesaid problem, battery cables get really hot, so hot that, when I get home, I have to wait 10 -15 minutes to disconnect the negative.
Old Sep 10, 2014 | 06:54 PM
Two weeks? You are lucky, my friend!
Old Sep 10, 2014 | 08:26 PM
Is it a short?
Thanks.
Check for a parastic draw.
Old Sep 11, 2014 | 07:40 AM
RKSmith163's Avatar
I remember a thread a few years back that said the OnStar module could be the culprit. There is a fuse under the hood that I think is on your Positive Battery Cable that can be pulled to confirm. I has been a while back so my memory if fuzzy. You could do a search using keywords OnStar Parasitic drain. Good Luck.
Old Sep 11, 2014 | 09:09 AM
Greetings:
Thanks.
Nice truck.
May I ask, when was the new battery installed, and did you have the problem before switching to this new battery? Just because a battery is new does not mean it is OK (It should be, but parts is parts and there are bad ones).
Old Sep 11, 2014 | 10:37 AM
happythree's Avatar
hot cables is overcharging while running. volts should not go over 15v
normal drain is checked with a milliamper meter in one batt cable, when first connected it reads apx 1 amp, then drops to 110 miliamp. close doors,no lights on.
1/10 of an amp steady.
Old Sep 11, 2014 | 11:01 AM
Thanks for the video. Will do, as soon as I can buy a new voltmeter. This morning, the 9 volt battery in my old Craftsman imploded.
