Battery drain h3 2007
Old Sep 11, 2014 | 11:05 AM
h3puertorico's Avatar
Yes, the problem was there with the "old" battery (Just 1.5 years old). New battery was tested and verified with a hydrometer, and with a machine at PEP.
Old Sep 11, 2014 | 11:10 AM
Originally Posted by RKSmith163
I remember a thread a few years back that said the OnStar module could be the culprit. There is a fuse under the hood that I think is on your Positive Battery Cable that can be pulled to confirm. I has been a while back so my memory if fuzzy. You could do a search using keywords OnStar Parasitic drain. Good Luck.
My first suspects were: OnStar; Radio; Alarm. So ALL of them were disconnected. In fact, radio was completely disconnected, since its fuse is the same for the A/C.
I also removed fuses for seat heaters and Sirius.
Old Sep 11, 2014 | 01:12 PM
Plan B. A problem for quite a few H3s is the wiring harness at the back of the truck to the tail lights and license plate light. Open the back door, look between the bumper and chassis where the wires go to the license plate light and trailer hitch (if you have one), on some trucks those wires rub on the chassis through the wire insulation and cause a short to the body.... which if that is what is going on, repeatedly drains the battery.
Check that out and let us know. It did it to mine until a re-routed the wires for more room and no rubbing. A friend had the same issue, and there is a thread bringing that up somewhere on here?
Old Sep 11, 2014 | 02:04 PM
I just took a look 2 minutes ago. Black plastic cover is intact. No exposed metal. (I confess I hoped that was the problem!)
Old Sep 11, 2014 | 02:46 PM
Well, that covered the easy stuff. Gonna take more work to figure out what yours is doing.
Good luck.
Old Sep 11, 2014 | 03:51 PM
happythree's Avatar
recheck that huh?
and,[QUOTEbattery cables get really hot, so hot ][/QUOTE]
NO wires should ever run hot. you really should monitor the volt s at off, startup, and running.
without that we know nothing.
Old Sep 11, 2014 | 04:49 PM
About the fuse: Page 428 Manual 2007 Fuse 13 : Radio, heating, air conditioning display, ventilation. In fact, when I Removed that fuse, no a/c came out.
Old Sep 11, 2014 | 06:30 PM
Good luck.
Thanks, anyway!
Old Sep 12, 2014 | 05:21 AM
brunoso's Avatar
Check your hand brake (foot brake). There are some wires that lay right behind the spring. That spring cut off the insulation on 4 wires on mine and made havoc. (blown fuses and burnt out my BCM module.
Old Sep 12, 2014 | 07:02 AM
No, no problem there (sadly!)
Can someone tell me the exact location of the BCM in my H3? A picture will help a lot.
