ATI superdamper
Old Nov 23, 2024 | 06:00 PM
OFFroadMonster's Avatar
Default ATI superdamper
I have a 2008 h3 alpha and will be changing the harmonic balancer.
Can I just remove the fan shroud and skid plate to gain access to the balancer or is there more to it?
Yes, the screen name is a joke.
Ive never been off road.
Old Nov 24, 2024 | 09:57 AM
Happy Hummer's Avatar
Old Nov 24, 2024 | 10:08 PM
I appreciate the link but the alpha has a 5.3L and is not the same as a 3.7 liter hence why I specified what I had.
They are defnitely not the same for what I’m doing.
It looks like there is enough room if I remove the clutch fan which is also different on the LS engines.
Old Nov 25, 2024 | 10:35 AM
Only way I have ever done it is with the Radiator out of the vehicle and the Condenser hanging off to the side. You might be able to fight with it for a while and leave the radiator in.... It would be a lot faster with the Radiator out of the way. I bet I could take mine out, R&R the Balancer, and put the Radiator back in faster than all the messing around trying to avoid that little bit of extra disassembly.
With that out of the way it is a straight shot with an Impact gun, puller then pusher, and final torque (Impact Uga-duggeda). I would think you will need to lock the flywheel to use a breaker bar otherwise?
Good luck. Let us know what you do.
Bigredh3
Jan 9, 2023 09:28 AM
mcioci
Sep 15, 2016 11:02 PM
Crawdaddyjc
Jun 15, 2016 04:25 PM
Monument Hummer
Sep 16, 2008 07:33 AM
jaxtrip
Nov 24, 2006 06:01 AM
