Aluminum Radiator Leak
Old Mar 28, 2018 | 01:38 PM
  #21
What are the 'CAR' aluminum radiators you're referring to. Want to make sure I don't buy one.
Radiators for a CAR? Luckily not the H3.
My first CSF leaked after about 2 months. They replaced it for free, just had to get the serial number off the bottom back of the radiator and send a pic of the leak. My vendor said CSF had an issue with their early H3 radiators????
My second one has had no issues. My first one has been fixed locally and ready for my next H3.
So MrClark, before you install it, take a good pic of the serial number (bottom rear of the radiator) just in case you have to do a replacement.
OHHH.....radiators FOR A CAR.....I thought he was referring to some brand I hadn't heard of......DUUUUH...
[QUOTE=MrClark;351103]
Oh my God, Oh my God, Oh my God!!!...lol I installed it this morning with out a thought of taking a picture of the serial number. But if it leaks I still have to take it out anyway. But thanks Doc for the info.
Sorry fellas, CSF Radiators. Stupid spell check on my not so smart phone.
Buddy (CB) bought 2, 2 failed within 4-5 months, they sent 2 new ones, 1 more failed within 4 months, the other in about a year. 2 more replacements, 1 leaker and 1 not (as of yet).
ALL started as a smell but no coolant, then small leak then a puddle. I have one in the garage now that I had tested before installing and it has a leak. Currently waiting for a replacement or a refund.
Old Mar 28, 2018 | 03:00 PM
  #22
Broken Halo's Avatar
[QUOTE=TAINTER;351111]
WOW! I figured CSF would be the 'go to' radiator if/when mine bites the dust. Now what?!
Old Mar 28, 2018 | 09:48 PM
  #23
happythree's Avatar
Default oh no!!
just got one for a jeep...
how to test first huh??
Old Mar 29, 2018 | 09:45 AM
  #24
[QUOTE=Broken Halo;351117]
I am going to go either with a Ron Davis $800 (aluminum radiator picture gallery from Ron Davis aluminum radiators) or a manual trans OEM radiator and install a separate cooler/fan.
Old Mar 30, 2018 | 04:57 AM
  #25
amrg's Avatar
I went with a griffin radiator. Its double the thickness of the RD radiator (helps with the hot summers). Doesn't have a trans cooler inside it though (I have an external trans cooler for that).
on a 70* winter day I had my coolant temps drop to 160* on the highway (I have a 160* t-stat). Trans temps were 120* (too cool)
Old Apr 10, 2018 | 12:26 AM
  #26
MrClark's Avatar
Finally my new radiator is in, The only problem with the install was the damn shroud it was a major pain.
but I got it in. as far as temperature its the same as the OEM radiator. My next move, when the weather gets
warmer Is to install an Efan and a tranny cooler.
Old Apr 10, 2018 | 11:06 AM
  #27
happythree's Avatar
not healthy for engine designed for 195, lubrication, efficiency,...
Old Nov 1, 2018 | 08:30 PM
  #28
MrClark's Avatar
Hey Doc 7 months later and I sprung a leak. Now heres the worst part there is no serial number on my radiator
Old Nov 2, 2018 | 07:19 AM
  #29
Where does CSF say the serial # is? Do you need it for a warranty replacement?
Your original receipt should be good enough, I would think.
Old Nov 2, 2018 | 09:52 AM
  #30
atvspeed4's Avatar
Keep us updated on this I have one I need to warranty soon and im sure the second one wont be far behind
