Alpha temp problems
The H3 cooling system requires ZERO bleeding when drained/refilled.
Common problem with the H3 cooling is after people go swamp doggy/mud bog and push dirt and crud up into the radiator, then fail to clean it.
Have you scanned the real temp? 3/4 on the idiot gauge is normal, so as far as I can tell, you do not have a problem.
I have a 2008 alpha as well. Yes the fan clutch is a pita on this car.
I replaced water pump, thermostat, radiator and hoses. I live in Atlanta and it does get hot. I do hit 3/4 temp as well and I can tell it's sluggish when it does.
well last couple of days i decided to mess with mine since its been running 3/4 temp after my cooling system overhaul.. well looks like i had air in my system.. i got it hot and took a handful of rags over the radiator cap and slowly opened. nothing but air came out.. i was able to pour about 1/2 gallon coolant straight in to radiator. now after driving today my thermostat got only a little over half in this atlanta ga heat.. even when idling at a stop light
As I said before, the H3 requires zero bleeding when drained and refilled.
Filling coolant:
Use 50/50 mix of Dexcool and distilled water = coolant.
Fill radiator until full.
Fill overflow tank until full to "Cold Fill" line.
Leave radiator cap off.
Start truck and check for leaks.
With the engine running, add coolant to radiator as necessary.
When truck reaches operating temp, the thermostat will open and the coolant level will drop. Add coolant to compensate and fill the radiator.
When full, shut off truck and replace cap.
Check coolant overflow tank level after driving at full operating temp.
Or you didn't fill it all the way when you put coolant back in.
Filling coolant:
Filling coolant:
rtwash
12-13-2013 10:45 PM
Andreas_Sweden
07-06-2011 03:07 PM
solarflare
25
01-21-2008 10:15 PM
