AC resistor
AC resistor
yes i have a 2006 H3 and i took my car to the dealer ship because the ac was not blowing any air when they found the problem they said it would take a week to come in but i dont have a week so i ordered the part should be here soon my only issue is where is the resistor pack? i cant find it and i know that this is a common problem if you guys know anything i really need help thanks....
They tend to be mounted through a hole in the heater box where they're cooled by fresh incoming air. At least that's where the one for my son's Cavalier is mounted. I'll never forget because it was a real PIA to reach it's associated mounting screw! LOL
If you have manual ac (meaning you have 3 ***** you turn) it should be bolted to the heater box next to the blower motor.
If you have digital or automatic air it is a module usually behind the display or under the dash.
I have an 03 H2 and the ac/heater display will not work. Checked fuses they are good. It will randomly turn on but for the most part it will stay off. Also had water leak in through the running lights from the roof which I sealed with silicone.
You appear to be asking a question about your H2, this thread is in the H3 section, where people ask questions about H3s. See how that works?
I suggest you post a new thread in the H2 section so that members that own H2s might see it and provide some help.
hummerhack
12-21-2013 03:28 PM
4u33er
05-17-2013 09:40 AM
