resistor wires
Old Jun 16, 2010 | 12:44 PM
redh3's Avatar
Default resistor wires
Could someone tell me the color code to the wires into the resistor connecter
Old Jun 16, 2010 | 07:09 PM
drtom's Avatar
Banned
Default best i can
+12 goes to motor+
motor - goes to conn a og=orange
another og e is high,direct to hi relay
then thru a res to pin l-bl lite blue med
then thru res to pin c tn tan another med speed
then thru res (third) to pin b ye yellow low speed
so there are 5 wires, a to motor is og
e also og to hi relay
then 3 res in series, the end of this string is low speed.
in past experience these were coils of res wire which are mounted in the air flow for cooling so they dont burn.
if one is open you can twist it together or jumper it(short) and use the fan with less speeds
since they pull the - motor to ground you cant hurt anything by shorting anything, the fan will just run,,,fast!
you mite find those letters on the conn,,dont know why 2 orang.
between a and e it shows 2 "things", could be thermal fuse link???dont know,, yet
grounding a or e should run fan,,if not , one of "things" is open
gud luk
tom
localmocha
Sep 3, 2016 05:40 AM
hmer
Mar 13, 2015 12:42 AM
hummerhack
Dec 21, 2013 03:28 PM
t2s9t
Jul 19, 2013 03:02 PM
4u33er
May 17, 2013 09:40 AM
