AC/heat fan problems :(
Old May 17, 2022 | 05:14 PM
bassackwards's Avatar
Default AC/heat fan problems :(
Hey all,
The fan quit working on our 06 H3 and it it hot!
It has sporadically ran and not worked of an on for a few months and now nothing, I pulled the resistor out and it looks ok. The connectors were clean and the harness looks newer. swapped around fuses and relays and no change.
Are there any electrical tests that I can check on it?
Old May 17, 2022 | 06:31 PM
Old May 18, 2022 | 09:53 AM
May we assume you already had the HVAC recall performed?
Old May 18, 2022 | 04:39 PM
I assume so. The section of wire from the resistor to the blower motor to the black and white plugs looked pretty new.
Old May 18, 2022 | 05:30 PM
Did some diagnostic testing as shown above and had these measurements at the plug
Setting Volts
0 0
1 13+
2 13+
3 13+
4 0
Do we need both a resistor and a new blower motor?
Old May 18, 2022 | 06:28 PM
H3MikeNY's Avatar
STOP RT THERE!!! Do not fall into the parts cannon “rabbit hole” as I did just a few short months ago.. Take a few mins and pull your glovebox out, after that your gunna C 2 white connectors,(pic 3) follow the one to your blower/resistor….. pull it apart and you’ll most likely find two burnt connectors, (pic 2) Either re-pin the harness connectors or purchase some quality crimp n shrink or solder n shrink butt connectors and by-pass the connector
Old May 18, 2022 | 07:24 PM
Ours looks new
Old May 18, 2022 | 07:26 PM
H3MikeNY's Avatar
Did you pull the connector apart and check for +v? I believe the orange wire should be batt v w/ key on….
Old May 18, 2022 | 07:50 PM
Originally Posted by bassackwards
Ours looks new
Resistor good, check voltage @ bm connector.
Old May 18, 2022 | 08:14 PM
At the plug we are getting about 10.5v on settings 1-3 and 0v on 4
