3 of 4 dorrs not unlocking when parked
Old Apr 18, 2021 | 12:33 PM
b3l14l's Avatar
Default 3 of 4 dorrs not unlocking when parked
I love my H3, but it seems when I get one thing fixed, something else happens. So a few days ago my 2006 H3 stopped unlocking the passenger side and both back doors when I put her in park. I checked the door lock program and it's set to Lock 1 which should unlock all doors. Everything else works fine. The door panel control was recently replaced and is about a month old. I tried disconnecting the negative battery cable to reset the BCM thinking it may help, but nope. Does anyone have any suggestions to get this working again? It's not a huge issue since I can still manually unlock the doors, but I like things to work the way they are intended. Thanks!
Old Apr 18, 2021 | 01:51 PM
That would be Lock 2. Try setting the different modes and check feedback:
Old Apr 18, 2021 | 05:21 PM
b3l14l's Avatar
I cycled through all 3 back to Lock 1 and it's still doing it.
Old Apr 18, 2021 | 05:36 PM
Did you get a different feedback from the other 2 modes?
Old Apr 18, 2021 | 05:42 PM
Also try installing the original master switch to check.
Old Apr 18, 2021 | 05:55 PM
b3l14l's Avatar
I didn't even think to check the other 2 modes ​​​​​​. I'll do that tomorrow and put the old switch back in if I have time and see what happens. Thank for the suggestions!
Old Apr 18, 2021 | 06:03 PM
10 second test between modes, to check bcm response. Btw, do you still get the 5x chime?
Old Apr 19, 2021 | 07:04 AM
b3l14l's Avatar
Got to check the lock programming this morning before work. Lock 2 and Lock 3 are working correctly. Lock 1 is still acting like Lock 2 and doesn't unlock the passemger/back door when shifted into park. I'll put the old control switch back in after work to see if that changes anything.
The chime did stop after putting in the new control switch! Thanks for the help on that one
Old Apr 19, 2021 | 04:12 PM
b3l14l's Avatar
Well, swapped out the control switch and put the old one back in. Works fine now, so the brand new one crapped out in a little over a month(?). Whatever happened to quality?
Anywho, thanks for the suggestions and advice!
Old Apr 19, 2021 | 04:55 PM
I didn't advise you to buy that cheap crap? RU still getting the repeated 5x chimes on the oe switch? Just take the master switch apart and clean the board and pad with rubbing alcohol or crc electronic contact cleaner. Btw, my master switch is still! OE!
Watch these how to videos & clean the board/carbon contacts.
