2020 GMC battery fits H3
Old Mar 4, 2025 | 11:42 AM
Default 2020 GMC battery fits H3
I had my GMC dealer replace the battery in my wife's 2020 at no charge with my gm rewards & received the old battery since it still tests good.
It's a group 48agm battery 2" longer(11") than the H3 group 86(9") battery with the same width to fit into the wedge mount hold down.
After removing the old battery, the lower plastic battery cover pulls out after removing 2 wiring harness connector clips attached.
Underneath the plastic cover the steel tray has an extra 2" length for an 11" long battery to set on. Then install the strap & wedge hold down to hold the battery secured in place.
Old Mar 4, 2025 | 04:25 PM
Anything will fit if you remove the darn batter tray! Why is this news?
I have 2 huge Optima Yellow Tops in the same location.
Old Mar 4, 2025 | 05:47 PM
Fits without modification is the reason for the post.
6-7/8" width fits secured in between the wedge hold down bracket mount. 11" length fits inside the metal edging border. Larger would require modification.
Old Mar 5, 2025 | 05:59 AM
Ahh, removing the battery cover and the battery base is NOT a modification. Sure!
Old Mar 7, 2025 | 11:53 AM
Happy Hummer's Avatar
Smile
Got some pictures or thread on this mod?
Old Mar 7, 2025 | 06:46 PM
Old Mar 10, 2025 | 12:54 PM
I'm thinking it looks just like this.....................
Old Mar 10, 2025 | 02:09 PM
wpage's Avatar
The tray is big enough to take much larger than the stock battery.
The stock battery is rinky dink and "bigger is better"...
Old Mar 10, 2025 | 04:45 PM
That's my "T", Thanks Doc!
reran all of the OEM wires after separating them from the OEM loom. re-loomed and heat shrank all the hydraulically crimped connectors.
Fuse cover still come off easily.
Old Mar 10, 2025 | 06:11 PM
YOU MODDED WITH PLASTIC BASE PLATES TO HOLD THOSE BATTERIES SECURED ON THE METAL EDGING BORDER FRAME BELOW!
BTW, OPTIMA BATTERIES R UNABLE TO HANDLE EXTREME TEMPS!
